It is currently Tue Oct 20, 2026 3:08 am
lesspostingmorewheeling
Post Posted: Tue Jun 17, 2008 8:49 pm
i finally thought of checking to see what the starter motor was doing so i hooked it up while it was out of the car and turned the key, the solenoid pushed out the pinion but it didn't turn does this sound like the starter motor or the thrust bearing? when the pinion is "in" it can be turned one way by hand but it can't be turned the other way is that right?
Mike
Post Posted: Tue Jun 17, 2008 9:48 pm
Mike
If I had to guess i'd say something like armature windings or brushes. It might be worth while cracking it open and having a look inside.
EDIT: This might help
Post Posted: Tue Jun 17, 2008 10:17 pm
i didn't think of that i thought the thrust bearing had seized but if that was the case the pinion wouldn't turn at all. i did get the starter to turn over after leveraging against the pinion but it only turned over a couple times slowly and then stopped
Post Posted: Wed Jun 18, 2008 12:11 am
Yeah something going on there. Siezed bearings? Bad electrical connections? Bit of both maybe...
Post Posted: Wed Jun 18, 2008 12:56 am
hi,
try using jumper leads and earthing the body of the motor (put yr foot on the thing) then touch the 2nd lead on the solenoid ( the one that runs into the starter body).
That will put 12v straight onto the motor. If it spins ok, the problem is in the contacts in the solenoid. If it doesnt spin, you've got bearing or brush problems..
good luck,
chris
Post Posted: Thu Jun 19, 2008 9:51 pm
nissvit wrote:
hi,
good luck,
chris
i tried that today and the starter spun so that means its in the solenoid? what can i do about that?
Users browsing this forum: No registered users and 222 guests
