| Distributor/modulator overheating? https://auszookers.com/forum/viewtopic.php?f=5&t=2319 |
| Author: | Lana [ Fri Jun 20, 2008 3:34 am ] |
| Post subject: | Distributor/modulator overheating? |
Hey guys, I'm having problems with my sierra stopping suddenly while driving (not fun on busy roads >.<) but then starting again fine after 5-10 minutes, until last time I drove it when I left it parked and then found it wouldn't start again at all. So the RAC guy said it was something to do with the distributor/modulator and it started again but he said it wasn't fixed and would probably do the same thing again anytime. I called some places about getting another 2nd hand dizzy and got quoted about $200, and told that they sell a lot of distributors for sierras because they have a common problem of the modulator (?) over heating. So, I'm just wondering if anyone else has also had this problem, or has any ideas about what else it could be? My mechanical knowledge is pretty much zero |
| Author: | royce [ Fri Jun 20, 2008 12:52 pm ] |
| Post subject: | Re: Distributor/modulator overheating? |
Hi Lana, Welcome to Auszookers sounds like a module to me, pretty common for ignition modules and a lot of eelctronic sensors over time to get affected by heat and stop working, then come good again later on the module itself shouldnt be to dear from most auto parts shops and a straight forward swap, its a matter of unscrewing the module and swapping the wires I would stay clear of a second hand dissy as its more than likely going to do the same thing soon enough anyway and dont worry about there being any similar posts already, we all understand that sierras are old and simple so sooner or later things will come up a few times over |
| Author: | joeblow [ Fri Jun 20, 2008 1:59 pm ] |
welcome.....another thing to try is to diconect the tank breather line from the charcoal canister that sits on the passenger side of the engine bay. these over time will break down the charcoal and block the breather causing the tank to pressurise and flood the engine, after a while when the pressure has subsided the engine will start again. charcoal cannisters are a service item...but nobody changes them..... |
| Author: | Lana [ Wed Jun 25, 2008 1:30 am ] |
Great, thanks guys, I'll replace the module first and then try the 2nd option if that fails, but they sound like simple enough solutions so fingers crossed it should be sweet =p Cheers again |
| Author: | Lana [ Wed Jul 02, 2008 3:38 am ] |
Ok so you'd think ordering a new module would be simple enough, even if I had to do some ringing around after the first place quoted me $400. But now the parts guy tells me the module is actually two parts, the Generator Assembly and the Igniter and so I'm not sure which one I need or whether maybe it's both...? I'm thinking the generator assembly but kinda want to be sure so I don't waste money on the wrong thing |
| Author: | royce [ Wed Jul 02, 2008 1:25 pm ] |
the igniter is the common bit to go, its the little box looking thing that wires connect to, not the ring with a heap of fine wire coiled around it inside the dizzy, to use technical descriptions there are ways to test to make sure its one or the other if you have access to somebody with a multimeter, always better to be sure than to jsut throw parts at something till it works |
| Author: | Rockhopper [ Thu Jul 03, 2008 2:39 am ] |
Sounds like the dude that quoted you $400 is trying to make a quick buck out of you. Most common problem would be the igniter. I havn't had to purchase one for any type of car over the last few years, but from memory shouldn't be anymore than $50 to around $125. Could be wrong but can't see it being anymore than that |
| Author: | joeblow [ Thu Jul 03, 2008 3:31 am ] |
if its genuine don't be surprised at the price. i was qouted 1000 bucks for a genuine 1.6 mpi throttle body. try find a dizzy specialist and see if they have anything lying around. alot of manufacturers use the same electronics. |
