It is currently Fri Nov 06, 2026 8:33 pm
Post Posted: Fri Jul 01, 2011 3:17 am
Has anyone turned off, cut, smashed or ripped out the constant beeping noise that goes off if you turn car off and leave Key in ignition and open the doors?
Post Posted: Fri Jul 01, 2011 3:27 am
Not sure about Jimny but most Toyotas can be unplugged at the steering column. It may also disable other features if it's an auto. That would be the first place I'd look. Otherwise find the beeper and fill it with silicone :twisted:
Post Posted: Fri Jul 01, 2011 3:31 am
Not Auto. And not sure if it is the same beeper as when you leave lights on as well?
To be honest I have not really looked yet. I was just seeing if anyone had done it to save me time breaking stuff I did not have too.
Post Posted: Fri Jul 01, 2011 3:33 am
That's why I unplug at the ignition barrel, then it still works for the lights on.
Post Posted: Fri Jul 01, 2011 3:34 am
Cool
Post Posted: Fri Jul 01, 2011 3:36 am
Jimny may not be the same, may not be as simple
Post Posted: Mon Jul 04, 2011 8:10 am
I found a post about this earlier, but can't remember where sorry. Anyways, I managed to disable the noise - was a matter of pulling out a wire under the steering column. Have a search on the net.
Users browsing this forum: Baz89, Google [Bot] and 96 guests
