It is currently Mon Oct 19, 2026 11:42 pm
lesspostingmorewheeling
Post Posted: Mon Jun 02, 2008 12:23 am
I've been fixing a few bits and pieces since i got my zook and well i finally got to the motor so i got a mate to give me a hand. we set the timing and tuned it up and got it running real nice then we adjusted the valves and thats where my problem started i bolted the valve cover back on and went to start it and it just wouldn't start so i checked the valves again and tried it again and still didn't start. it wasn't turning over the best so i thought it might of been the battery so i replaced that and that didn't really help now i think the starter motor has had it because it grinds and only works half time. has anyone had similar problems? i'm new to this sort of stuff so any help or advice would be muchly apreciated
Mike
Post Posted: Mon Jun 02, 2008 12:33 am
did you move or remove the distributor when you pulled the valve cover off?
Post Posted: Mon Jun 02, 2008 12:50 am
nah when it was running we set it at 8degrees BTDC like it says on the bonnet and didn't touch it after that
Post Posted: Mon Jun 02, 2008 12:54 am
did you pull the leads off or the cap off to get the valve cover on and off?
sure nobody moved the dizzy? very hard to get the cover off without it
Post Posted: Mon Jun 02, 2008 1:02 am
i'm pretty sure, i checked the firing order before i reconected the leads i checked to see if it was was getting spark with an old plug and it wasn't getting the brightest spark
Post Posted: Tue Jun 24, 2008 3:06 am
sounds like one or more of the valves aren't opening which could cause a compression lockup and hence, the slow cranking.I would check the valve clearances again. Other than that it sounds a bit like retarded timing.
Post Posted: Tue Jun 24, 2008 3:12 am
someone told me that if a car blows black smoke it can be the rings or the vavles i'm not sure if thats true or not but it used to blow shit loads of smoke could that have something to do with it?
Post Posted: Tue Jun 24, 2008 10:12 am
smoke
black = fuel/ running rich
blue = oil burning, rings, valve stem seals
white = trans oil, brake fluid burning
Vehicle: 75 Cruiser
Post Posted: Tue Jun 24, 2008 10:34 am
excessive amounts of steam = water being pumped straight in to manifold :oops:
Post Posted: Tue Jun 24, 2008 9:57 pm
it blew blacks smoke then i added some no smoke now its sort of light grey
Post Posted: Wed Jun 25, 2008 1:28 am
Black smoke means it's getting too much fuel
Post Posted: Wed Jun 25, 2008 1:32 am
its never really run that lean with the weber on it. everyone has told me that its the rings and its only going to last about 5 mins
Post Posted: Wed Jun 25, 2008 1:36 am
that stuff is no good in the fuel tank
Post Posted: Wed Jun 25, 2008 1:39 am
its not in there :lol: i put it in after i changed the oil
Users browsing this forum: No registered users and 245 guests
