https://auszookers.com/forum/
VSS
https://auszookers.com/forum/viewtopic.php?f=5&t=23891
Author:  4x4zook [ Fri Jul 15, 2011 1:22 pm ]
Post subject:  VSS
hi guys. recently got my sierra with a 1.6 efi vitara motor running but i havnt got the VSS. cold i use a VSS from another 1.6 vitara if could find a dash cluster at a wrekers? does it haveto be the same model as mines a 97?
Author:  mnemonix [ Fri Jul 15, 2011 1:23 pm ]
Post subject:  Re: VSS
Any suzuki vss will do the job. vitara, baleno. All good.
Author:  fordem [ Fri Jul 15, 2011 2:08 pm ]
Take a look in the build thread (I think) there's a post detailing how to add a VSS to a Sierra cluster using a reed switch and a scrap of perforated board.
Make that the "I made it and fabrication" thread
Here you go
Author:  runtbase [ Fri Jul 15, 2011 9:45 pm ]
What does this vss do you speak of.
Author:  want33s [ Fri Jul 15, 2011 10:11 pm ]
VSS is Vehicle Speed Sensor.
It is just another sensor to tell the ECM how fast the vehicle is going in relation to throttle position.
Car will run fine without it but if connected and working, will use less fuel, especially on the highway.
Author:  runtbase [ Fri Jul 15, 2011 11:21 pm ]
I have a aftermarket ecu microtec does that mean vss would not work with this??
Author:  fordem [ Sat Jul 16, 2011 12:02 am ]
Check your ECU manual - it may or may not have an input for it - and if it can accept one, then it will need to be programmed to make use of it - so you're probably better off leaving it as it is.
