It is currently Sat Nov 07, 2026 12:09 am
Post Posted: Tue Jul 19, 2011 4:32 am
So a few of you guys are running a chromo front end in your LJs. Have I got the right idea as to what you do here?
From what I figure you use Chromo Sierra CVs and Custom axles? I'm guessing the Sierra CVs means you have to do a disc brake swap? Can I buy the axles off anyone or do I need to get my own made? Of course, I'l need to put rear diff spider gears in the front for the 26 splines, I think that's about it. :oops:
Am I close or way off? :lol:
Thanks
Hayden
Post Posted: Tue Jul 19, 2011 4:42 am
As I understand it you put SJ Joints on LJ housings with LJ diff and axels and SJ drums or disks :lol: .
Of course this may be wroung :cry:
Post Posted: Tue Jul 19, 2011 4:43 am
yep. buy chromo cvs without the axles from low range.
think i paid about $100 per cv. yes it means either disk swap, or finding 1 litre drum brakes
custom inner axles. we got them made by a friend.
we may have a run being done again soon, but not sure when.
Post Posted: Tue Jul 19, 2011 4:57 am
Okay, thanks mate!
Let me know when you're doing another run of the axles please! Approximately how much are they?
You just run standard Stockman rear ends don't you?
Post Posted: Tue Jul 19, 2011 5:09 am
yep. though were looking at full floats rears soon too.
not sure what the cost will be as the cost of steel has gone up since.
ours were some where around the $200 mark per shaft
Post Posted: Tue Jul 19, 2011 5:26 am
Awesome, thanks again mate.
Now to just try and keep a spare $500 for when you make them. 8O
Vehicle: LJ50V, SJ70
Post Posted: Tue Jul 19, 2011 6:26 am
How close in length is a WT right hand/short shaft to a LJ50 shaft?
Post Posted: Tue Jul 19, 2011 6:29 am
front shafts? not sure.
i know that the coily rear short side shaft is exact for length with a 50 shaft.
i picked one up but then never bothered finding a second one for 26 spline upgrade
Post Posted: Tue Jul 19, 2011 6:48 am
I had measured up a WT rear diff to use 2 short shafts to make a shortened diff housing for an LJ50 that would take an air locker and JoeBlow rear discs, and 2 WT short shafts would have made the perfect width.
Post Posted: Tue Jul 19, 2011 6:51 am
there is about 15-20mm difference in length between coily and WT
lj50 shafts are the same as coily down to the mm from memory
Post Posted: Tue Jul 19, 2011 7:04 am
Quite a bit different I think. The Sierra short side front are really short. I Did have a 1L one somewhere that I could add 50mm to and get an estimate from.
Clearance Hole Technology :P
Post Posted: Tue Jul 19, 2011 8:47 am
I still have a few axles left from the last batch, heat treated 4140. They are 26 spline inner and 25 spline outer for the crmo CVs. Not sure what it'll cost to send them to you. Mine's twin locked on 32" tyres with 6.5 gears and they're solid. Guess once you get the CVs I can send them. $150 each. (plus post) Guess that should see them to WA under $200 each.
Users browsing this forum: Google [Bot] and 106 guests
