It is currently Sat Nov 07, 2026 12:09 am
Post Posted: Wed Jul 20, 2011 12:08 pm
im about to do a ruf, i am going to buy new springs but sifting through the posts i find a lot of conflicting facts...... i need to know if i need 2" lifted rear springs up front as well as up the back or...... have 2"lifted rear and stock rear springs up front arrrrrrrrrrrrr i need help
Vehicle: SJ51T
Post Posted: Wed Jul 20, 2011 12:09 pm
standard rears in the front. lifted rears in the rear
Post Posted: Wed Jul 20, 2011 12:22 pm
I had lifted efs rears all round, with a RUF via redrilled spring perches.
Worked well, i had a arb bar upfront.
Post Posted: Wed Jul 20, 2011 12:25 pm
Depends how high you want it to end up. You can go stock rear up front with raised in the rear or 2 inch rears all round with extended shackles in the rear to bring it up to the same height as the front.
Post Posted: Wed Jul 20, 2011 6:41 pm
Flat rear sierra springs with drilled rear spring mounts and 50mm longer shackles will equal a 50mm lift springs in the rear.
Chassis extentions with stock rear springs and stock shackles will not give you any lift.
Users browsing this forum: Google [Bot] and 105 guests
