It is currently Tue Oct 20, 2026 12:44 am
Post Posted: Sat Jul 05, 2008 8:51 pm
well i pick up a set of landcruiser 60 diffs tomorrow and will be starting to put them in next weekend.
any tips from people that have done it.would be good. they are going into a 84 1ltr chassis
Post Posted: Sat Jul 05, 2008 8:57 pm
why go 60 diffs...hard enough to get them into a 40 series.
Post Posted: Sat Jul 05, 2008 10:56 pm
width, the rear pumpkin if off set the same as a zook diff, bigger every thing as i want to run 33 + wheels and i got them, drive shafts and power steering box cheap.
was going to go hilux but to much stuffing around with the rear drive shaft.
Post Posted: Sun Jul 06, 2008 3:52 am
60 diffs with 33 or 35's is like a sierra running 30's...no real benefit, and the vehicle will be over gvm. and its a lot of rotating mass to get moving.
Post Posted: Sun Jul 06, 2008 2:32 pm
i want to go the diffs because it will be spoa so the extra width is good, more weight down low won't hurt and with clearing the center if it doesnt clear i'll take another line. don't get to many deep rutted tracks around here and if they are you can drive aroung them. i want it to play on rocks and big angles
my last car was spoa sierra axles with 33 and it was very tippy, kept breacking things and very under braked for the weight of the wheels on the road so i wanted bigger brakes and more width better raito in the diff.
how much more do you think the diffs are? they are about 60 -70 kgs (rough guess as i know the centers are 31 and the housing is 24) each end and sierras are about 40kgs i'd say.
i'm not going with a sierra engine, i'm going a piazza ( 110 kw @ 5400 and 225nm @3000) and auto box so that will turn them pretty well i think.
Post Posted: Sun Jul 06, 2008 4:25 pm
you want this thing legal?.....cause it won't happen. and as far as spoa on sierra's 99.9% of them are done wrong by people who think they know what they are doing. we have a few down here that are settup correctly, but not cheaply, and they don't have any dramas, and they are 100% legal.
Post Posted: Sun Jul 06, 2008 6:57 pm
why would it not be legal? i'm going as wide as i'm going up, all the extra weight is down low, bigger brakes. the only thing i think i will have a problem is the spua to spoa. you can engineneer spoa here and there is a car pretty much the same (its lwb mine will be swb) as i'm doing engineneed with a flip front in sydney and canberra is the same rule book.
the spoa is pretty much for the approach, ramp over angles and to fit the centers.
the last car was done right, all the caster was right and drove very stable at speed, didnt wander, get speed wobbles or light in the steering. if i was staying with the 1.3 and staying sierra diffs i'd keep it spua and lockers but the 1'3 doesn't have the go i want to drive on the road or the brakes to stop if you need to on the road. i was breaking stuff already in the last car and the angles i want to play on i need more width.
i was going to go hilux diff but they have less track and then the 60's i have more problems with the rear tail shaft but the plus with them are they are spoa stock and a bit lighter
Post Posted: Sun Jul 06, 2008 9:25 pm
got some pics of the old setup? most engineers nowadays follow the ruling of no more than 150mm height increase from stock roof height. spoa and 60 diffs will prob be too much. also be weary of new engine laws too.
Post Posted: Sun Jul 06, 2008 11:14 pm
how do i post up pics? i'll put some up of the old car.
Post Posted: Sun Jul 06, 2008 11:20 pm
click post reply, scroll down to add an attachment, click browse, find the pic on your pc and click OK, then click add attachment and wait for it to upload, then type something of a reply and hit submit
Post Posted: Mon Jul 07, 2008 12:15 am
now i feel dumb. its saying the file is to big, i'm usless with computers and don't know how to make it smaller.
Post Posted: Mon Jul 07, 2008 12:27 am
this is the olny pic i have that is small enought (taken buy my phone) showing the front. its when it was on 31's.
Post Posted: Mon Jul 07, 2008 12:51 am
google image resizer powertoy and install it, you can right click a photo and make a smaller version then
Post Posted: Mon Jul 07, 2008 3:11 pm
herr we go , hope they work
Post Posted: Mon Jul 07, 2008 5:15 pm
got any detailed pics of the suspension?
Post Posted: Mon Jul 07, 2008 7:59 pm
no sorry, just got pick of driving it and when i was working out the shocks. the front diff was moved forward buy re drilling the spring pads back a bit and the high steer was a nuckel job not the brake caliper. i didn't do the spoa on that car, i got it like that and just sorted the shocks and engine out.
at full flex the front uni would bind and kill it self so on the 60 diffs if its the same i might give a nuckel and rotate ago to try to stop it.
Users browsing this forum: No registered users and 282 guests
