It is currently Mon Oct 19, 2026 5:47 pm
Post Posted: Sun Jul 06, 2008 9:11 pm
hey guys,
i just brought a sierra ute and was running ok on the way home but then started to lose power and would not idel when it would come to a stop and keeps dieing and wont even idel now. anyone know the problem??? i was thinking about ditching the stock carby and going to a webber but i dont know if that would fix the problem.
any info or help would be good,
thanks sam.
Post Posted: Sun Jul 06, 2008 9:30 pm
could be full of dirt or the idle solenoid could be stuffed
best to give it a tune and clean the carby out to begin with, always ahrder with a new car cause you dont know the history of the problem
Post Posted: Mon Jul 07, 2008 11:07 am
Ain't that the truth. Just bought a car with a full service history that has been serviced at the Suzuki dealer all it's life. Decided to give it a major service anyway. So far I've repaired stuffed rear axle bearings, rear brake shoes and wheel cylinders, water pump, radiator, timing belt, water pump & air con belts and fixed an air leak at the carby. Now I remember why I only trust myself to repair my cars :roll:
In your case, it does sound like a carby problem. Remove the cover over the top of the carby, give it a rev and put you hand or a rag over the top of the carby to creat a vacuum. Just before the engine stalls, remove your hand and let it rev again. Return to idle. If it's just a bit of crap in the carby, often you'll find that will fix the problem. If it's more than just a bit, you'll have to strip it down.
Post Posted: Mon Jul 07, 2008 11:34 am
Dealers are great for doing half arsed jobs. More than a few times I have had to do partial rebuilds on cars that have been looked after by dealers all their lives. And they really know how to charge too!!
Users browsing this forum: Google [Bot] and 223 guests
