It is currently Mon Oct 19, 2026 9:48 pm
lesspostingmorewheeling
Post Posted: Thu Jul 10, 2008 10:50 pm
i bought some shocks today that are a fair bit longer than the originals
when a car is sitting flat how much up travel does it need?
Post Posted: Thu Jul 10, 2008 11:08 pm
about 15mm more than the distance between bumpstops
Post Posted: Thu Jul 10, 2008 11:37 pm
well i'm stuffed then, the shocks i got when they are fully compressed the diff is about 3 inches away from the bumpstop
Post Posted: Fri Jul 11, 2008 12:14 am
commondore sedan?
Post Posted: Fri Jul 11, 2008 12:17 am
yep vs/vr sedan rears i have to take them back though because the bottom bolt doesn't fit in the bushing in the shock
Post Posted: Fri Jul 11, 2008 12:26 am
bush too big?
swap in the sierra ones or hit Bruce up for some new ones
Post Posted: Fri Jul 11, 2008 12:30 am
its like a pressed in metal one someone posted a part number for vp wagen rears, would i be better trying to get a set of those?
Post Posted: Fri Jul 11, 2008 12:31 am
yes you would
Post Posted: Fri Jul 11, 2008 12:37 am
will they be long enough for 30mm higher than standard reset rears and longer shackles?
Post Posted: Fri Jul 11, 2008 12:41 am
they are pretty well long enough for most ruf setups, anything more youll need ranchos and shock hoops that cost more than a sierra :P
Post Posted: Fri Jul 11, 2008 12:54 am
the other number that was posted was for liteace rears i got a set of hilux rears that were a bit longer should i just get the ones that someone posted in this thread? oh yeah by the way do you know anywhere tother than supercheap that sell gabriel?
Post Posted: Fri Jul 11, 2008 1:00 am
dunno, its the compressed length you need to worry about
not in Tasmania :)
Post Posted: Fri Jul 11, 2008 1:35 am
i meant do any of the major chains other than super cheap stock them?
Post Posted: Fri Jul 11, 2008 11:06 am
nobody bothers to stock anything supercheap pushes
National parts used to keep a few but they closed down
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 205 guests
