It is currently Mon Oct 19, 2026 6:01 am
Post Posted: Sun Jul 13, 2008 5:41 am
i have 2'' lifted springs and was wondering would i be able to use them in a spoa conversion-but i dont want extreme height.
so i was thinking would it work if i just took some leaves out? if so how many??
lesspostingmorewheeling
Post Posted: Sun Jul 13, 2008 5:46 am
i'm by no means an expert but you should be able to use the springs
are they heavier duty than standards? or are they just higher?
Post Posted: Sun Jul 13, 2008 6:24 am
im not sure if the're heavier duty but there's 5 leaves in 1 pack,the standard 1's only had 3 a pack.
they are 2'' taller.
Post Posted: Sun Jul 13, 2008 6:30 am
standard springs have 4 leaves and and over load leaf
this is a reset standard compared to a 65mm lifted spring
if you want to lower the springs you got take out the second leaf, the one above the load leaf but this will also make the spring softer
Post Posted: Sun Jul 13, 2008 7:53 am
:roll: mm ok cool cheers good to know
Post Posted: Sun Jul 13, 2008 1:54 pm
A spring over would get you a fair bit of lift, maybe 5"?? Should be going for standard flat springs, no lift at all. What size tyre do you plan on running?
I see you also want a body lift in another thread.
SPOA plus a body lift is huge on such a short wheel base. Think about virtual lifts and moving your diffs before going so high if you want to fit bigger tyres.
Post Posted: Sun Jul 13, 2008 2:13 pm
nah ill think ill just stay spua for the moment.i only want to run 31's anyway and seeing blusuzy flex up looks awsum. but thanx for the comment
Post Posted: Sun Jul 13, 2008 5:00 pm
if you only want to runn 31's stay spua and put a 2 inch body lift in
with spoa you'll fit 33" wheels no problems with no body lift but move your front diff forward a inch.
Users browsing this forum: Google [Bot], gpalaciosa and 395 guests
