| Air Filter Set Up https://auszookers.com/forum/viewtopic.php?f=5&t=2472 |
| Author: | Mike [ Sat Jul 12, 2008 1:59 am ] |
| Post subject: | Air Filter Set Up |
i've got a 32/36 weber on my zook with one of the shiny round airfilters (mines red does anyone have pics of air filter set ups they are running on a weber or setups with a snorkel on a weber? cheers |
| Author: | Brett [ Sat Jul 12, 2008 2:34 am ] |
| Post subject: | Re: Air Filter Set Up |
it only starts to be a problem if the top of you air cleaner is very close to your carby throat. anything under a 1.5" between the carby and hat might cause a problem but the sierra engine doesn't really use much air so if the air cleaner is clean you'll be fine. |
| Author: | Mike [ Sat Jul 12, 2008 2:38 am ] |
mine sucks like a vacuum cleaner you can hear it over the exhaust but its not tuned and its jetted for an escort |
| Author: | Brett [ Sat Jul 12, 2008 2:51 am ] |
most webbers are like that i'd be changine the pri jet to a smaller one, will make a big change to the car and the fuel it uses. a good carby shop will be able to work out what one is pretty close. does the car bog down much? even with light load? if so you will prob be running rich and even worst when you go w.o.t |
| Author: | Mike [ Sat Jul 12, 2008 2:57 am ] |
it sounds a bit suggish and crap to about 2000revs then after that it clears up but i don't think the secondaries are working properly |
| Author: | Brett [ Sat Jul 12, 2008 3:02 am ] |
its been a few years since i worked on a webber but if i remember right (might of been a holly i'm thinking of) you can take out the pri jet pretty easy. go get a pri jet 2 steps down to lean it out a bit and see how that goes. |
| Author: | Mike [ Sat Jul 12, 2008 3:05 am ] |
i downloaded a weber manual for a sierra so i'll just try to work out what i have to take apart would the manifold have anything to do with it? |
| Author: | Brett [ Sat Jul 12, 2008 3:12 am ] |
yes if there is a big step from the bottom of the carby to manifold but the jet will have more of an effect because the mixture is out to start with. and escort engine it about 1/3 bigger than a sierra so 1/3 more fuel is going in the engine. the manifold will upset air speed but that isn't a big problem till you port heads and start dropping the air speed going past the vavles |
| Author: | Mike [ Sat Jul 12, 2008 3:17 am ] |
my manifold has the flange off the escort manifold welded on in place of the suzuki and its all been smoothed out and shit so that should be better than using an adapter plate would it matter that its a pre polution carby? |
| Author: | Brett [ Sat Jul 12, 2008 3:26 am ] |
only if you get pulled over the jets will make a huge difference! i had a stroker 308 that never reved past 5000, was running rich when driving and running out of fuel when reving. changed the pri jet 2 steps down and sec jets 3 up. 1st time out with nothing change reved to 7800 still pulling before i backed off and broke one of my axles from the lights on the way home |
| Author: | Mike [ Sat Jul 12, 2008 3:39 am ] |
i'll have to look at the jets next mine still likes to rev i saw it rev off the tacho before i bought it and thats a motor that has done 200,000ks what did you have the 308 stroker in? |
| Author: | Brett [ Sat Jul 12, 2008 3:44 am ] |
it was in a hj windowless panel van. should of never sold the car, got less than the engine cost me and the guy pulled the engine out and put a stock engine in and was using if for a promo car in vic last i heard but i need a work car as i just went out subbing he told me what he was doing when he picked it up and i nearly cryed because i could fo swaped a 253 i had and sold it to him cheaper and every one would of been happy. |
| Author: | Mike [ Sat Jul 12, 2008 3:49 am ] |
i'm not a holden fan by any strech of the imagination but i still think its a shame when that sort of thing happens panel vans are cool i've never met someone who has a car like that, that they didn't regret selling |
| Author: | Brett [ Sat Jul 12, 2008 3:56 am ] |
most of the time its because of the money they put in. i had the car for 4 years and out of that 4 years it was on the road for 5 months. i kept breaking things because i got shafted with party that weren't what was told so they broke. so now i do all my work myself and then i know its done right. its also heaps cheaper! |
| Author: | Mike [ Sat Jul 12, 2008 4:01 am ] |
yeah and if you do it yourself you can do things that mechanics won't do or think are unsafe |
| Author: | Brett [ Sat Jul 12, 2008 4:03 am ] |
that was the best quote i've heard in a long time!! and that is why you have a sierra |
| Author: | Mike [ Sat Jul 12, 2008 4:15 am ] |
thats right if i wanted to act all old and serious and get stuff done by a mechanic i would of bought a vitara |
| Author: | Nik [ Fri Jul 18, 2008 12:09 am ] |
If youd put weber as the thread name you would have got my attention sooner!!! Ok I had 1 of those 9" chrome pos on mine and changed it to a lynx ramflo (about $50) and it made an improvement striaght induction instead of up and over choke horns. Yuo have to jet the weber for the zuk engine to make it perform, you think its good now wait till you jet it properly Starting guide only, primary/ secondary idle 55/60 50 main 140 140 air 170 160 e tubes f50 f50 This is a guide and the secondary will depend on what size aux jet you are running base is for 3.5 aux, 4.5 possibly smaller jets. E tubes are expensive (approx $20 each) but will make it run better. Mine was always rich at idle till I changed to f50 e tubes. At w.o.t. the weber will realy roar but when jetted correctly are quiet good on fuel as you rarely need the secondaries. Intake work will also reap rewards smooth taper from adapter into manifold and plenium into runners. Im setting up a 38 which is a syncro so both throats open together and a fully ported manifold. Still in the sorting stage but more power than the 32/36. For more info go to www.performancewebers.com or check out weber info on www.zuwharrie.com Check out your jets and post up to see if we can better it for you. Youll also need to do a plug test to see how primary and secondaries are running. Nik Heres my latest set up
