It is currently Sat Nov 07, 2026 12:38 am
Post Posted: Sun Aug 14, 2011 12:40 am
I made enquiries with a few brake suppliers yesterday for my 08 Jimny. A couple said their books showed different part numbers for different years.
So, how many variations are there for both front and rear, and rotors?
Found an eBay seller that suggests that his product suits all models.
eBay Disk Brake pads
and
eBay Brake Shoes
and
eBay Disc rotors
So which is correct? Same throughout, or variations?
edit: Also, anyone know these brands and the quality?
Post Posted: Sun Aug 14, 2011 1:20 am
Did later ones come with ABS? If so the rotors would have sensor rings, shoes and pads are the same I think.
Post Posted: Sun Aug 14, 2011 1:30 am
There is a variance... What year model they changed I am not sure.. The disc are different.
I think it was Zukenutter who came across it. From memory it is not because of the abs.. But a change in the hub... The centre hole in the new model disc are slightly larger
Post Posted: Sun Aug 14, 2011 3:14 am
I have a full set from an earlier front end. No idea what year but might do a comparison.
The ABS sensor ring is separate from the disc, but will see if it changes anything.
Post Posted: Mon Aug 15, 2011 9:45 am
I also would like opinions on weather holes or slots in a rotor would help channel away dirt and water, hence reducing the wear of the pads over a time.
eBay performance discs
Also, the seller of the pads offers 3 variants. Are these likely to be 3 different qualities, or matter to me with regards to performance and wear?
eBay Pads and Rotor seller
Vehicle: On the lookout
Post Posted: Tue Aug 16, 2011 5:12 am
I've only ever found I get less dust with the higher quality pads. On a couple of performance vehicles I've owned the brake fade was much lesser too, but I can't think it would make a jot of difference on a 900kg jimny with it's throbbing 1.3 powerhouse.
I fitted the slotted rotors off this very guy on ebay on my pajero and they were good quality. I hammered the hell out of them - 2000kg of automatic Pajero slowing from 110kph - 0kph on the daily drive home regularly and they didn't warp unlike the factory rotors which warped pretty quickly.
Post Posted: Tue Aug 16, 2011 5:23 am
Aftermarket drilled rotors have been known to get stress cracks at the holes. Slotted, eg DBA ones are meant to be really good, especially after water crossings etc as they self-clean faster.
I don't think the pads will have reduced wear though. I thought it was quite the opposite. I thought you get better braking, ie less brake fade at the expense of pad life.
EDIT: Those DBA rotors in your first ebay link are dimpled not cross drilled so shouldn't have stress crack the problems I mentioned above.
2002 SWB GV
Lifted and Locked
Post Posted: Tue Aug 16, 2011 8:46 am
I expect the slots would have more effect on draining/self cleaning than holes or dimples, so thats what I'll be looking for at some point.
Post Posted: Wed Aug 17, 2011 11:09 am
I think that the rotors changed at the same time as VVT models with optional ABS.I think the bigger main hole was due to ABS ready hubs. Is only a mm difference. I have a pair of early model rotors which I'll get machined. I haven't been able to find after-market rotors for VVT Jimny.
Users browsing this forum: No registered users and 111 guests
