It is currently Mon Oct 19, 2026 4:19 am
lesspostingmorewheeling
Post Posted: Fri Jul 11, 2008 11:59 pm
i finally decided what springs to get i got some EFS rears and new i've got a couple questions before i stuff everything up :roll:
i got some gabriel shocks off a liteace and they are about 3 inches longer than what i've got at them moment is that gonna be long enough for 65mm lifted springs
my next question is what leaf should i take out because they are fairly stiff?
my last question is when i put the rears up front do i need to do anything to the springs eg. take out leaves or put some of the front leaves in the rear pack?
cheers
Vehicle: 75 Cruiser
Post Posted: Sat Jul 12, 2008 12:03 am
in the pic, i'd take out the leaf above the load leaf, (load leaf being the bottom straight one.
Post Posted: Sat Jul 12, 2008 12:07 am
if you are using standard mounts extended length means nothing, you want to make sure the diff will hit the bumpstops before the shock bottoms out, IE the COMPRESSED length is not longer than the distance between shock mounts fully compressed, though in this case it will be fine I think
I would pull the short curved leaf out and put it in your standard rear to go in the front, I think stock rears arent stiff enough for fronts and collapse pretty easy (my best was 24 hours)
should i take the spring clamps off and do you think those shocks will be enough?
Post Posted: Sat Jul 12, 2008 12:10 am
dont take the clamps off, see what they do at full flex first
the key to good suspension is one small mod at a time, get to know how it works in all situations then make a change so you know how it changes things
I went all out massive soft springs, massive shocks and it all flexed awsome and looked cool, but try and climb a rutted hill and it was all over the place and shit, its all about balance
Post Posted: Sat Jul 12, 2008 12:13 am
do i leave the load leaf off the rears when i put it in the front? which way should that bracket thing on the spring face?
Post Posted: Sat Jul 12, 2008 12:18 am
yes take the load leaf off
spring will only go in 1 way
Post Posted: Sat Jul 12, 2008 12:22 am
i just remember that :roll:
so take the leaf about the load leaf out of the new rears then put that leaf in the old rears and take off the load leaf?
does that make sense?
Post Posted: Sat Jul 12, 2008 12:23 am
makes sense to a sierra owner, I wouldnt be inclined to ask people in the street though :wink:
Post Posted: Sat Jul 12, 2008 12:26 am
its fun asking susupention places for commodore shocks to fit a sierra :lol:
Post Posted: Sat Jul 12, 2008 1:27 am
do i take the short leaf off the old rears or do i just put the short leaf from the new springs under it, should i have 4 or 5 leaves in the front?
Post Posted: Sat Jul 12, 2008 1:35 am
just add it on
nothing will be final cause you will have to tinker with adding and removing springs to get it just right
Post Posted: Sat Jul 12, 2008 1:43 am
i'm hoping i won't have to do to much with them anything will be better than the set up i've got at the moment
am i gonna need longer brake lines?
Vehicle: 75 Cruiser
Post Posted: Sat Jul 12, 2008 1:45 am
yer the front usually needs longer lines once you more than the usual 2inch lift.
Post Posted: Sat Jul 12, 2008 1:47 am
i thought so will the i need a rear one too?
Vehicle: 75 Cruiser
Post Posted: Sat Jul 12, 2008 1:57 am
i don't think the rear one is that bad, flex it up and have a look. I think you can get away without extending the rear one, but you could do it anyway just for bling factor.
Post Posted: Sat Jul 12, 2008 2:01 am
do they make red brake lines :wink:
Post Posted: Sat Jul 12, 2008 3:32 am
you will need to drill you rear spring mout about 20 mm back aswell so your steering links don't get cought up when flexing. i think the aim is to have you diff about 1 " to 1.5" forward from stock and every thing sholud be fine
Post Posted: Sat Jul 12, 2008 3:35 am
my steering links are all bent :lol:
i didn't realise i had to do that, i'd like to try it without drilling the holes first because i'd more than likely stuff that up
Post Posted: Sat Jul 12, 2008 3:39 am
it will move you diif forwad a bit, you'll have to redrill the spring pad forward of the axle to move the diff back a bit but will make the car very stable if you steering works
Post Posted: Sat Jul 12, 2008 3:44 am
wow i didn't realise i had so much work ahead of me, looks like i won't have it back together for a while :roll:
at least i won't have to worry about the front tyres scrubbing anymore
Post Posted: Sat Jul 12, 2008 3:46 am
not much more work, just to more holes drilled. you'll have it apart any way. just run a tape over every thing twice before you drill.
Post Posted: Sat Jul 12, 2008 3:50 am
how far which way do i have to drill the spring perches?
Post Posted: Sat Jul 12, 2008 3:58 am
can't remember off the top of my head ,think about 20 mm forward of the axle to move the diff back 20 mm
Post Posted: Sat Jul 12, 2008 4:04 am
so i want to move the diff back around an inch?
Post Posted: Sat Jul 12, 2008 4:06 am
yes because the spring will move it forward about 2 or 3 and then the steering gets stuffed up.
Users browsing this forum: No registered users and 399 guests
