It is currently Sat Nov 07, 2026 12:08 am
Vehicle: 03 Jimny
Post Posted: Thu Aug 18, 2011 7:57 am
Hey I'm having drouble trying to get the rev tacho in my sierra to read.
I've change the wires as many way you can but still does Nit move when I put my foot on the accelerator.
Could it be a bugged cluster.
Also I done falcon alt upgrade.
Falcon alt thread said to use 70amp but I had shit loads of dual battery cable.
Does any one see a problem running 100amp cable from alt to battery
And what size fuse would be good with 100amp wire.
Post Posted: Thu Aug 18, 2011 8:03 am
Running larger cable than required is fine. Use the same fuse as you would with 70amp cable, it's there to protect more than just the cable...
I want my old sig back :(
Vehicle: 03 Jimny
Post Posted: Thu Aug 18, 2011 8:54 am
Cheers Ben, any one no what's the go with rev reading.
Sits just undering 1000rpm and doesn't go up or down.
Stays in the one spot.
Users browsing this forum: Google [Bot] and 105 guests
