It is currently Mon Oct 19, 2026 9:16 am
Post new topic Reply to topic  [ 66 posts ]  Go to page 1, 2, 3  Next
Post Posted: Mon Jul 14, 2008 12:01 am
Anyone know anywhere inside aus that sells a decent shackle reversal kit? Looking for a cheap way to lift a sierra and just wondering if anyone is in the know.
lesspostingmorewheeling
Post Posted: Mon Jul 14, 2008 12:06 am
snake racing sell the calmini shackle reversal kit its not cheap though ist $895 but you get everything you need
Post Posted: Mon Jul 14, 2008 12:12 am
http://www.lowrangeoffroad.com/samsuspkits.htm
Right down the bottom, Warrior Shackle Reversal. Would not be much to get it out here either. With my last order from these guys I was going to get a T/Case bucket, pretty bulky and that was going to less than $100 for shipping.
Post Posted: Mon Jul 14, 2008 12:35 am
the low range one would be the cheaper option but you don't get as much with it, the calmini one it a 2inch lift kit so you get rear shackles too
this the the low range warrior kit
this it the calmini kit
Post Posted: Mon Jul 14, 2008 12:44 am
go the lowrange kit, youll throw the rest of the calmini stuff out for better bits anyway
and the cheapest way is to do a bodylift, dont bother trying to lift suspension on the cheap it wont work
Post Posted: Mon Jul 14, 2008 12:46 am
is calmini stuff as crap as everyone makes out?
Post Posted: Mon Jul 14, 2008 12:51 am
you guys are real quick but thanks. how does the low range one work is it only the back or do you need two?
Post Posted: Mon Jul 14, 2008 12:54 am
its well built stuff that fits like a glove and does exactly what it says it will do
but we know lifting a sierra 5" without any custom fab work is never going to be the best way and trying to get another 2" lift from stock height springs is going to mean massive extensions on other bits
1 size fits all sierra suspension really finishes at your typical OME, EFS, Kings ets kits and after that you build what you need to suit you, a kits just never going to work
you only put a shackle reversal on the front
Post Posted: Mon Jul 14, 2008 1:08 am
and just longer shackles on the back or how does it give lift that would just make the front stick up?
Post Posted: Mon Jul 14, 2008 1:15 am
It would probably not give a huge amount of lift. The shackles are included and don't seem that long. So you may not nheed longer ones in the back.
Don't forget it will also put your castor way out wack. Wedges may correct this though.
Why did you ask about where to get a shackle reversal kit before you knew what one was??
If you are just looking for height I would do what royce said a put a body lift in. With some 2 inch springs you will clear 31's easy.
Post Posted: Mon Jul 14, 2008 1:19 am
the calmini kit comes with the longer rear shackles
i'm not sure about the low range kit it probably doesn't give any lift
Post Posted: Mon Jul 14, 2008 1:24 am
i asked to learn mostly if i knew i wouldnt have to ask. I saw the calmini one on a us site. the low range doesnt look to difficult to make up though
Post Posted: Mon Jul 14, 2008 1:56 am
it would be less work to just get the low range kit there would be a bit of mucking around making your own
Post Posted: Mon Jul 14, 2008 2:04 am
why are you lifting you car, run bigger wheels, want more flex or just the wank factor?
if its to run bigger wheels go a 2 inch body lift, with a bit if guard bashing will fit 31 inch wheels.
if you want more flex the easy thing to do is 2 inch lifted springs and pull a leaf out of the packs and go from there or 2" in the rear and the old rears up front will flex more but has a bit more work with that. you can get heaps of flex out of the car before going a s/r
Post Posted: Mon Jul 14, 2008 3:49 am
pretty much a mixture of the three. I dont really want to take to my car with a hammer that just doesnt go down well with me yet so i sort of wanted max legal lift cheap and i thought this was a possibility.
Post Posted: Mon Jul 14, 2008 3:52 am
what sort of springs are you using at the moment?
Post Posted: Mon Jul 14, 2008 3:59 am
just the stock ones hey mike you might know when people say they want to use commodore and hilux shocks to what purpose do these serve?
Post Posted: Mon Jul 14, 2008 4:03 am
just get some springs and a body lift its all fair easy to do and it can be done on "the cheap"
people use commodore rear shocks in the front and hilux rears in the back
they have a lot more travel and its cheaper than buying rachos that are like 150bucks each
Post Posted: Mon Jul 14, 2008 4:07 am
just cruizin showed me a very good way to get the lift i want for around $800 without the shackle reversal
Post Posted: Mon Jul 14, 2008 4:09 am
Putting new springs in the rear, old rears in the front, Supercheap shockies (commo and hilux), new u bolts and spring bushes, extended shackles and a bodylift can be done for $800 and would take you a full day to install.
Post Posted: Mon Jul 14, 2008 4:12 am
thats exactly what i'm doing at the moment :lol:
Post Posted: Mon Jul 14, 2008 4:18 am
and its all perfectly legal?
Post Posted: Mon Jul 14, 2008 4:23 am
i have no idea i live in tassie and all thats sort of stuff is pretty relaxed i think 2 inch spring lift and 2inch body lift are legal though
once again if you put the rears up front do the original rears have to have anything done to them (reset at stock or higher)? or can i just pull it out paint it and stick it back under there
Post Posted: Mon Jul 14, 2008 4:27 am
take off the load leaf.
i got efs 65mm springs and they were a bit too high so i took the second leaf out of the new ones and put them at the bottom of the old rears
Post Posted: Mon Jul 14, 2008 4:30 am
oh ok but they still stay at relatively stock hieght?
Post Posted: Mon Jul 14, 2008 4:33 am
putting the old rears in the front will give about 2inches of lift
Post Posted: Mon Jul 14, 2008 4:37 am
and that is just with moving the mount back around 25mm isnt it?
Post Posted: Mon Jul 14, 2008 4:41 am
nah you have to do that aswell because when you put the rears in the front it moves the front diff forward too much so redrilling the mount on the diff will move the back so it doesn't stuff up your steering
Users browsing this forum: No registered users and 261 guests
