It is currently Sat Nov 07, 2026 3:03 am
Post Posted: Fri Aug 19, 2011 6:26 am
Was just having a brain storm the other day, Is the Gearing in a Sierra Gear Box / Transfer better than the gearing in a Vitara Gearbox / Transfer???.
Im running 31's under my Vit atm and as everyone knows the 1.6L G16b isn't a powerhouse to turn those bad boys.
Stocker
Post Posted: Fri Aug 19, 2011 6:30 am
gearbox is the same, transfer runs lower transfer gears
Post Posted: Fri Aug 19, 2011 6:34 am
Vitara diff gears are lower than sierra aswell.
Are better Gearbox Ratio's available?
Stocker
Post Posted: Fri Aug 19, 2011 6:42 am
you cant change gearbox ratios, you can get reduction for the transfer
Post Posted: Fri Aug 19, 2011 6:46 am
i see... so i might chuck that bit of paper in the bin because i can get lower transfer gears already :)
Cheers for the input :)
Stocker
Post Posted: Fri Aug 19, 2011 6:48 am
they are expensive but it can be done. look up the undertaker for vitaras
Post Posted: Fri Aug 19, 2011 6:55 am
yeahh i have seen them. as little to adventurous for my liking of price :) I will turbo it before i do that :)
Stocker
Post Posted: Fri Aug 19, 2011 7:00 am
IMO gearing is more important than power.
Post Posted: Fri Aug 19, 2011 7:17 am
Sierra tcase behind yours or a auto box is the cheapest way. my car turned them no problem because of the auto
Post Posted: Fri Aug 19, 2011 7:28 am
The biggest difference between sierra and but transfers is the high range. Vit cases have 1:1 high range, but sierra cases have a reduction in high range. AND the reduction is greater with aftermarket gears.
Post Posted: Fri Aug 19, 2011 9:57 am
Sierra reduction is 1.2 in high
Vehicle: LJ50V, SJ70
Post Posted: Fri Aug 19, 2011 12:15 pm
1.3 Sierra is 1.41, 1.0 transfer is 1.58
Users browsing this forum: No registered users and 371 guests
