It is currently Sat Nov 07, 2026 3:03 am
Post Posted: Sat Aug 20, 2011 7:55 am
Anyone know if they fit with a few mods to the brackets?
Post Posted: Sat Aug 20, 2011 9:24 am
you need to cut some mounts off here and there but they sit to low so you either need to lift the body up or cut the floor to lift it up
josh AKA Bazook
Post Posted: Sat Aug 20, 2011 5:48 pm
I have a 2 inch body lift... I may lift the back floor up abit if needed... Only a 2 seater car anyway....
Vehicle: Sierra Ute '87 Sj70
Post Posted: Sat Aug 20, 2011 10:15 pm
Well would it fit in my ute? I've got easily 8" of room under my tray above the tank
It's all coming together Armsup
Post Posted: Sun Aug 21, 2011 6:29 am
I'm 99% sure the LWB tank won't fit between the chassis rails, which is part of the reason this one was mounted like this:
I'd say the centreline flange of the tank would have to above the rail, which is going to put the tank a long way into the passenger compartment.
Great for clearance, but pretty limiting and annoying for carrying anything.
The SWB tanks fit without a problem.
Regardless, all mounts have to change. It's quite a big job.
Users browsing this forum: No registered users and 372 guests
