It is currently Sat Nov 07, 2026 1:43 am
Post Posted: Wed Aug 24, 2011 3:35 am
G'day AZ Crew, not sure how obvious this is but I've been doing this for years now with the padlock on the back of the Vitara as I'm a bit paranoid about the padlock seizing up due to lack of use & mud/water/crap getting in the barrel of the lock.
Tools Required:
Duct Tape & Sharp Knife.
Spare Wheel Padlock.
Make sure the lock is clean & apply tape.
Pull off enough tape to wrap around the other side.
Wrap tape around to other side & make sure you get a good seal.
Jobe Done, I also wrapped the bolt of the padlock with electrical tape to thicken it up so it doesn't rattle around in the hole & added a small pad of sticky back foam on the top flat area so it doesn't scratch the rim. :oops:
Post Posted: Wed Aug 24, 2011 3:39 am
Won't water, dust etc also get in through where the U-shaped bolt goes in as well (i.e. through the top)?
2002 SWB GV
Lifted and Locked
Post Posted: Wed Aug 24, 2011 3:47 am
when closed the leccy tape around the bolt makes a pretty good seal. i've got a small lockwood padlock on my letterbox that's been in the weather for 4 years & it's rooted, infact it's just hanging off the letterbox as a decoration. the one on the back of the zook for 6 years & opens like a dream.
it might have something to do with being horizontal & the one on my letterbox is vertical?
Post Posted: Wed Aug 24, 2011 4:12 am
Could you orientate the padlock so it's upside down and the open end with the bolt is lower then the (now gaffa taped) keyhole end? That way water can't get in.
2002 SWB GV
Lifted and Locked
Post Posted: Wed Aug 24, 2011 5:33 am
http://en.wikipedia.org/wiki/Capillary_action
Post Posted: Wed Aug 24, 2011 5:40 am
As opposed to being right way up and filling with water (not withstanding the black tape around the bolt)????
Besides being upside down the constant vibration/shaking from being on a vehicle would help drain the padlock as well.
2002 SWB GV
Lifted and Locked
Post Posted: Wed Aug 24, 2011 5:45 am
Rain generally flows past a small hole, but is very likely to be sucked 'up' into it.
Most padlocks I've seen liquid can flow both directions, so the drainage doesn't really matter that much.
Post Posted: Wed Aug 24, 2011 6:04 am
fark, why make something so simple difficult. :roll:
have alook at the room where the padlock is & tell me how i'm going ot orientate it so it upside & so it stays there, do i use a fucking sky hook?
Post Posted: Wed Aug 24, 2011 6:13 am
Oh you wanted a simple solution???? :crazy: . My bad...
2002 SWB GV
Lifted and Locked
Vehicle: SJ80, SE416
Post Posted: Wed Aug 24, 2011 6:37 am
I have previously dropped a few drops of oil into a padlock i used to have outdoors. I opened it and poured the oil into the open hole at the top and it eventually got down past the key lock
It seemed to keep the workings free from corrosion - would that be a good idea?
Post Posted: Wed Aug 24, 2011 6:42 am
That's what I do with all my mine as well. Works well.
Post Posted: Wed Aug 24, 2011 6:57 am
I squirt inox in my two padlocks on the pod trailer, being at the rear they cop alot of road grime from both car and the pod.
Its kept them in top working order.
Vehicle: jimny
Post Posted: Wed Aug 24, 2011 8:30 am
Gus you could silicone up the bolt section and also the key hole, just peel it away when needing to open it, mrs rav 4 had the same issue, I just pushed grease onto the key hole and the open bolt end, still worked fine when I tested it after 12 months. Also helps if you use a quality lock as well
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Wed Aug 24, 2011 8:44 am
I just use the Lockwood combination locks on my outdoor ones. and spray some wd40 on them about once a year or if they get sticky, also I don't have to worry about loosing the key and you can set them all to the same number.
Lockwood have a rating system on the back of the packet that actually points out how tolerant they are to water/outdoor use too. but generally the more you pay the beterer
http://www.nothingbutpadlocks.com/produ ... f-padlocks we use the third one down on the link on the spares on our trucks, no probs
Post Posted: Wed Aug 24, 2011 8:45 am
wouldn't oils & such attract & hold the dirt & dust inside the lock?
that lock is a top of the line Yale stainless steel lock & has been in that same spot for the last 6 years & has been kept clean with duct tape & duct tape only.
Post Posted: Wed Aug 24, 2011 9:15 am
i just run a bike lock through the wheel, its working fine, last time i checked
Vehicle: LWB Sierra & XL7
Post Posted: Wed Aug 24, 2011 10:40 am
Gus, That is an extremely simple, quick and effective solution and cost less than 10cents. :)
'92 Vitara & Camper trailer
Post Posted: Wed Aug 24, 2011 10:47 am
You brown noser :lol: yeah what he said :wink:
Post Posted: Thu Aug 25, 2011 9:13 am
Even easier, do away with the padlock, and use an m12 x 40 cup head bolt, with a wing nut on the back of it. The robbers will take one look at it, and think its all to hard, and go steal someone elses :wink:
Go Hard, Trailer Home
Users browsing this forum: No registered users and 109 guests
