It is currently Tue Oct 20, 2026 6:35 pm
Post Posted: Fri Aug 26, 2011 4:00 am
Hi Guys,
Thanks to all those who helped with previous advice but I've got another question.
I'm going to go ahead with a conversion, current car 92 Vit with G16A and donor car is 97 Vit with J20A (both auto). Was hoping to see if its possible to do a full transplant, I'm interested if anyone can tell me if the 97 dash will fit into the 93?
If the entire dash and cluster are not transferable does anyone have a wiring diagram which I could use for the conversion?
Thanks in advance,
Michael
Post Posted: Fri Aug 26, 2011 4:08 am
i'm sure the dashboard will "fit" but you might need to transfer over the mounting brackets off the dash bar & i'd be doing a full loom swap rather than a cut & shut.
Post Posted: Fri Aug 26, 2011 4:41 am
The model inbetween yours and the SV's has a 1.6 with a variation of the SV dash so it should go no problems, but like Atari says swap the whole thing over looms and all
Post Posted: Fri Aug 26, 2011 7:05 am
Thanks guys, will definitely swap everything over then, loom and all. Donor car was involved in a front ender and I managed to buy the complete car.
Time to make some working space.
Cheers,
Michael
Vehicle: 93 vitara g16a
Post Posted: Sat Jan 11, 2014 2:03 pm
Did the j20a mounts match the existing g16a mounts?
Vehicle: Vitara 1995
Post Posted: Fri Mar 10, 2017 1:40 pm
hey Friski, how did you remove the dash do you recall?
Users browsing this forum: Google [Bot] and 218 guests
