| Dash Swap Possible (G16A & J20A) https://auszookers.com/forum/viewtopic.php?f=5&t=25152 |
| Author: | Friski [ Fri Aug 26, 2011 4:00 am ] |
| Post subject: | Dash Swap Possible (G16A & J20A) |
Hi Guys, Thanks to all those who helped with previous advice but I've got another question. I'm going to go ahead with a conversion, current car 92 Vit with G16A and donor car is 97 Vit with J20A (both auto). Was hoping to see if its possible to do a full transplant, I'm interested if anyone can tell me if the 97 dash will fit into the 93? If the entire dash and cluster are not transferable does anyone have a wiring diagram which I could use for the conversion? Thanks in advance, Michael |
| Author: | atari4x4 [ Fri Aug 26, 2011 4:08 am ] |
| Post subject: | Re: Dash Swap Possible (G16A & J20A) |
i'm sure the dashboard will "fit" but you might need to transfer over the mounting brackets off the dash bar & i'd be doing a full loom swap rather than a cut & shut. |
| Author: | royce [ Fri Aug 26, 2011 4:41 am ] |
The model inbetween yours and the SV's has a 1.6 with a variation of the SV dash so it should go no problems, but like Atari says swap the whole thing over looms and all |
| Author: | Friski [ Fri Aug 26, 2011 7:05 am ] |
Thanks guys, will definitely swap everything over then, loom and all. Donor car was involved in a front ender and I managed to buy the complete car. Time to make some working space. Cheers, Michael |
| Author: | aquaminor [ Sat Jan 11, 2014 2:03 pm ] |
Did the j20a mounts match the existing g16a mounts? |
| Author: | bristlenose2008 [ Fri Mar 10, 2017 1:40 pm ] |
hey Friski, how did you remove the dash do you recall? Sent from my iPhone using Tapatalk |
