It is currently Mon Oct 19, 2026 1:54 am
Post Posted: Thu Jul 17, 2008 1:59 am
hi
i was just woundring what mods you have to do to run 31 muddys under a zook i got a 2'' lift with exstanded shackels and a 1L trnsfercase.
lesspostingmorewheeling
Post Posted: Thu Jul 17, 2008 2:00 am
you'll need a body lift cut the front chassis outriggers off and maybe smooth out the lips inside the guards
Post Posted: Thu Jul 17, 2008 2:07 am
to run them nicely piss those extended shackles off and run a 50mm spring lift and 50mm bodylift.
Post Posted: Thu Jul 17, 2008 2:10 am
will the 1L transfercase run 31s
wish i had another zuk
Post Posted: Thu Jul 17, 2008 2:14 am
you can run 31s with a 1.3 transfercase, it would be better with the 1 litre case than a 1.3
Post Posted: Thu Jul 17, 2008 2:17 am
but most people put reductive gears in the 1.3 transfercase when going over 30
Post Posted: Thu Jul 17, 2008 2:20 am
i have 31's on my sierra with a standard 1.3 transfercase
the one litre transfercase is geared lower which corrects for the tyres a bit
the gearing isn't back to what it used to be with standard tyres but its closer than the 1.3
Post Posted: Thu Jul 17, 2008 2:32 am
with joe blows reccomendations everything will be legal except the tyres where as now your car has the extended shackles it could be done by the boys in blue
Post Posted: Thu Jul 17, 2008 2:42 am
IF you submit the paperwork for the body-lift to the transport department, & then get it approved & inspected, it would be legal, except for the tyres & extended shackles... (in QLD anyway)
What driving do you want to do? Transfer gears can be had from the US for around $600-$700 at the moment with the good conversion rate.
This suits very low speed (crawling) over rocks etc, if you want a bit faster low-range (mud bashin etc) maybe keep it as is...
Just a note though, if you do start doing any hard/steep/slow speed 4x4ing theres a good chance you will burn your clutch out (my mates went the first day he took his car out on 31's with standard t'case and that wanst any hard stuff)...So if this happens, by the time to do a clutch replacement a second time you may as well have bought the gears to start with...
Post Posted: Thu Jul 17, 2008 2:47 am
remember that for us running the 1.3 xfer case the 1.0 is better but because your speedo is already set up for the 1.0 it will be just the same out as if we left our 1.3 in. Reduction gears is probably the best way to go if you can spend the cash otherwise try it out burn out a clutch then when your bank recovers from that get the gears
Post Posted: Thu Jul 17, 2008 2:52 am
for those of you in vic you can get the 31's legal too. :lol:
Post Posted: Thu Jul 17, 2008 3:01 am
its just another plate isnt it?
Post Posted: Thu Jul 17, 2008 12:20 pm
hi guys i am unning 31's on my zook 1.3 and it runs them fine i got 2 inch body 2 inch spring and cut them rail things off and i can get full flex to the bump stops reduction gear help but not needed... if u put the 1L transfer that counter's the 31s.....
Post Posted: Thu Jul 17, 2008 2:58 pm
i do more mud driving than rock, hill climing
Post Posted: Thu Jul 17, 2008 5:23 pm
it doesn't matter what terrain you do, gearing determines load on a driveline. there is a formula which the industry uses. to run 31's properly you will need more than a one litre transfer, either diff gears or t/case gears. if you want to even the load up correctly and gain as much power back than diff gears are the way to go. if you want to get the engine revving to almost its original state while putting more load in mounts, uni's and other components after the t/case outputs than go t/case gears.
Post Posted: Thu Jul 17, 2008 8:36 pm
I think he has 1ltr zuk though, so the 1 ltr T/case in that is stock gearing.
You could get some 1.3ltr diff housings with Vitara 5.12 centres. Would lower your gearing a bit. Or spending similar dollars and just get some transfer gears from the states.
Post Posted: Thu Jul 17, 2008 8:43 pm
that is pretty much what i meant that because the car is set up for those gears it doesnt help him having it as much as if a 1.3L owner had those gears
Post Posted: Sat Jul 19, 2008 3:12 am
how much power do you lose with the 1.3
Post Posted: Sat Jul 19, 2008 3:17 am
a bit i got a weber and it was noticable you probably want to do something to compensate
Post Posted: Sat Jul 19, 2008 3:19 am
i been wanting to but a 180B in it but can't find 1 around
Post Posted: Sat Jul 19, 2008 3:25 am
180b?
Post Posted: Sat Jul 19, 2008 3:27 am
out of a datsun
Post Posted: Sat Jul 19, 2008 3:36 am
i'd really like one of those 2.5 litre v6s out of a vitara :roll:
Post Posted: Sat Jul 19, 2008 4:21 am
the L18 out of an old datsun really wont help u a lot......old cast iron block and very heavy compared to the g13 out of a sierra or even the g16 out of the vitara
333...................im only half evil
Post Posted: Sat Jul 19, 2008 4:29 am
my dream engine swap would be a worked 12a rotary, always loved rotary's and that way you could have the best of both worlds 4x4 and heaps of power
Post Posted: Sat Jul 19, 2008 4:40 am
yeah but no torque
[quote="zookkid"]yeah but no torque,rotors cant pull shit- so ive herd
Post Posted: Sat Jul 19, 2008 4:41 am
they don't have much torque though thats the only problem but that aside it will work and it has been done
Post Posted: Sat Jul 19, 2008 4:47 am
and they have a shit load of power for the weight. As long as you have traction it would get you were you wanted
Post Posted: Sat Jul 19, 2008 4:51 am
i think there is one with a 13B down here somewhere
Users browsing this forum: No registered users and 400 guests
