https://auszookers.com/forum/
Alternator - Voltage Regulator, Sierra 91
https://auszookers.com/forum/viewtopic.php?f=5&t=25391
Author:  Dale [ Sat Sep 03, 2011 8:09 am ]
Post subject:  Alternator - Voltage Regulator, Sierra 91
Hey Guys,
Recently on a trip away my voltage regulator failed, well I think it has. I checked the voltage over the battery and it is about +16v when the car is running. I went to the wreckers and found a 1990 barina alternator, it appears to be identical to the 1.3lt sierra one. I then changed the voltage regulator over to my sierra alternator. However it is still charging above 16v, any ideas?? I did not change the rectifier over
The barina regulator might also be stuffed?
Thanks guys,
Dale
Author:  Rusho [ Sat Sep 03, 2011 8:16 am ]
Post subject:  Re: Alternator - Voltage Regulator, Sierra 91
16v 8O 8O Try another reg, you may have been unlucky twice :lol:
Author:  Rhino [ Sat Sep 03, 2011 8:28 am ]
Have you checked the sence wire that goes into the altinator for a voltage drop?
I have upgraded mine directly from the battery thru a relay as it had a 2v drop across the factory wiring.
Author:  Dale [ Tue Sep 13, 2011 10:25 pm ]
Thanks Guys, yes the second voltage regulator was also stuffed. Grabbed another one from the wreckers and it now works. However it appears I have cooked both my main and dual battery plus the dual battery automatic isolator/charging thing.
All fixed now.
Dale
Author:  steak_knife [ Wed Sep 14, 2011 6:41 am ]
Please tell more????
