It is currently Sun Nov 08, 2026 9:21 pm
Post new topic Reply to topic  [ 75 posts ]  Go to page 1, 2, 3  Next
Vehicle: 1995 SWB Sierra TinTop
Post Posted: Sun Sep 11, 2011 11:32 am
hey guys just found this tyre on ebay :D
its a exact replica of a simex centrepede and there only $189.00 each haha not like $350.00 haha
http://www.ebay.com.au/itm/Insa-Turbo-S ... 27bdb2bdd4
anyone heard about these tyres???
im going to buy 4 in the next couple months and there only $100 delivered to brisbane from melbourne :twisted:
95 Sierra SJ70 TinTop
Post Posted: Sun Sep 11, 2011 11:37 am
yep, i have them in a 235/75r15 & they're are taller than my 31" MTR's 8)
235/75r15's v 31/10.5r15 :?
they are a remold tyre... eg retread, they work well off road, bloody noisy on road & they're heavy as hell, as a play only tyre they're perfect.
Post Posted: Sun Sep 11, 2011 11:38 am
are they soft???? well kinda soft?
Post Posted: Sun Sep 11, 2011 11:45 am
tread seems quite sticky & side walls seem pretty flexy.
Front right at basically 0psi
Post Posted: Sun Sep 11, 2011 11:49 am
im going to buy them as a comp tyre so they should go pretty well haha run like 5psi all day on a suzi with a 6 inch rim, shouldnt ever pop a bead, unless something bad happens haha
Post Posted: Sun Sep 11, 2011 11:56 am
I'll consider these when my present tyres wear out.
Was very happy with my Mongrels,
these should be just as good.
Softness of sidewall usually is good,
because they 2nd hand carcass broken in by some heavy 4wd junk.:)
Post Posted: Sun Sep 11, 2011 12:01 pm
so a coiled sierra? haha :helloo:
Anyone (I know 3cyl has! :P ) tried the Sahara?
http://www.ebay.com.au/itm/Insa-Turbo-S ... 2315wt_648
Cheap muddies FTW! Armsup
Post Posted: Sun Sep 11, 2011 12:07 pm
235/85 16's is perfect for a zook,
but I'd have to buy rims as well.
So a tall 235 on my 15's sounds like my choice.
Post Posted: Sun Sep 11, 2011 12:10 pm
Can they be used on road or are they comp only?
Post Posted: Sun Sep 11, 2011 12:15 pm
they are a street legal tyre, i did a 600km round trip on them with a heap of highway driving... my stereo was about up louder by about 5 or 6 & it doesn't even come close to drowning out the noise. it's like you are being chased by a hover craft & my fuel economy blew out wickedly
Post Posted: Sun Sep 11, 2011 12:16 pm
x2 that's the size I want.
Pity 235s don't come in really high profiles.
http://www.insatyres.com.au/
road legal as far as I can tell
Post Posted: Sun Sep 11, 2011 12:21 pm
Just remember, the size they state is the carcass size then they have an inch or more of tread wrapped over the top.
Thats why the 235's Gus got off me are 31's when usually they should be a 29".
Vehicle: Hard Top Fusty Ducker Vitara
Post Posted: Sun Sep 11, 2011 2:23 pm
So being such a heavier tyre blows out the fuel milage but by how much?
Tyres look really awesome with a heap of bite and I actually looked into these tyres not long ago. Only thing is that say the sahara's are only a difference of about $20 to buy the Maxiss bighorns brand new off ebay.
I'm still considering these tyres as an option though as I'm sure the performance will be huge.
Nah doesn't look that deep.......fck
Post Posted: Sun Sep 11, 2011 2:29 pm
The weight and the added rolling resistance would be it @ 110kph it was something like 4l per 100km worse than my normal mud tyres.
Post Posted: Sun Sep 11, 2011 9:35 pm
I can't see the tyre weight adding to an increased fuel milage, rather, the aggressive tread pattern.
Post Posted: Sun Sep 11, 2011 10:30 pm
dont forget cos of the increase in size the odometer is way out as well (unless you measured speed and mileage by gps?)
Vehicle: 89 vitara
Post Posted: Mon Sep 12, 2011 8:17 am
are they cheap and crappy atari?
i would use them for going away, but the noise on the road would be horrible
Post Posted: Mon Sep 12, 2011 8:24 am
my tyre guy way quite impressed with the quality of them for a retread, they are a full remold rather than a recap. eg the new rubber goes from bead to bead.
alien when fitted there is very little difference in size & surely not enough difference to blow it out by 4L/100kms 8O
Post Posted: Mon Sep 12, 2011 8:33 am
Made in the UK, the standard's there make what we do here look like dark age's....
Post Posted: Mon Sep 12, 2011 8:41 am
Your motor has to work ALOT harder to get that extra weight moving.
Post Posted: Mon Sep 12, 2011 9:14 am
Actually its the tread design that causes the huge increase in fuel use. I experimented with my sierra when i got the silverstone xtremes. same size AT was 5ltr better than the xtremes per 100km's. The big lugs created more air drag and at hwy speeds created more resistance and that needed more throttle to keep speeds.
Was almost no difference around town but when you had to go over 80km/h it really sucked.
Post Posted: Mon Sep 12, 2011 9:27 am
Shakes, not disbelieving you, but I look at it this way, even if the tyre was double in weight to "normal" tyres, over all the weight increase is very insignificant.
Add two passengers and you have far more weight, but that will not reduce fuel consumption by 40% or so.
Post Posted: Mon Sep 12, 2011 10:29 am
With those tyres on my vit, i used half a tank more fuel on trip up to morgan than i did with my mtr's on on the same trip :wink:
Post Posted: Mon Sep 12, 2011 10:54 am
I found these one look the same as the ebay one I emailed them but I got no reply
http://www.china4x4accessories.com/product.asp?cid=27
 Profile YIM
Post Posted: Mon Sep 12, 2011 10:56 am
i can say that they weigh a metric truckload more than my 31's.
what ever it is, it's almost like driving around with the handbrake on a few clicks, dip the clutch in & it doesn't coast to a stop, it rolls for a bit then stops.
as B4T said around town they were no worse in the way of fuel usage, but on the open road it's pretty bad.
Post Posted: Mon Sep 12, 2011 11:02 am
Your motor isn't trying to turn the passengers end over end ;)
b4t has proven me wrong though
Post Posted: Mon Sep 12, 2011 11:13 am
Tread pattern, not weight.
Post Posted: Mon Sep 12, 2011 11:15 am
as shakes said, rotation mass is a big factor.
Users browsing this forum: No registered users and 93 guests
