It is currently Sun Nov 08, 2026 8:13 am
Post Posted: Mon Sep 12, 2011 7:38 am
:helloo:
My jimny has a bit of a lean...well a 30mm lean, over to the drivers side :? . I can not figure out what is causing this, the front springs got replaced 2 weeks, with 80mm Tough dog HD coils (+30mm coils spacers in the front) and the rear has tough dog 80mm lifted coils to.
It has been this way for about 3-4 months now, and i can not find any reason for the "lean", i have checked the coils towers and they all seem straighten and UN-damged.
Could the rear drivers side coil be sagged even though it hardly has weight on it? If the panhard rods, were slightly out of adjustment would this cause issues?
It's pissing me off, so any one have any idea's whats causing this?
Cheers,
Monkey.
P.S. it has been like this pre-bent diff days. :roll:
Post Posted: Mon Sep 12, 2011 7:46 am
Easy, don't jump jimnys and don't eat so many burgers ;)
Sorry mate that's all I got...I'm sure the sierra boys will jump in as they to can suffer from the dreaded sideways lean.
Post Posted: Mon Sep 12, 2011 7:47 am
I would say dodgey springs. Possibly wrong rate on one?
Obviously you have checked that the drivers side spring and passenger side spring are right way around?
Post Posted: Mon Sep 12, 2011 7:50 am
This was pre jumped days :lol: and I only weigh 70kg :roll:
Post Posted: Mon Sep 12, 2011 7:52 am
The springs are the right way round, I even tried different springs in the rear to see if it was the springs....it was not, it still leans over.
Vehicle: Suzuki Grand Vitara
Post Posted: Mon Sep 12, 2011 7:55 am
I had the same problem with my Vitara, so I added a spring spacer to just the rear drivers side.
Vehicle: 2001 Jimny M13A
Post Posted: Mon Sep 12, 2011 9:00 am
Hey Monkey,
Have you got your rear springs on the right side??
My 60mm TD were different lengths (about 15mm) and marked R for right and L for left from memory.
Jimny Shocks and Springs :P
Post Posted: Mon Sep 12, 2011 10:03 am
Yep there are in the right way, long spring goes on the drivers side.
Post Posted: Mon Sep 12, 2011 10:13 am
Its called.. "Swagger"
If in doubt power out!
Post Posted: Mon Sep 12, 2011 10:26 am
rofl
Post Posted: Mon Sep 12, 2011 10:30 am
Bahahahahaha
Post Posted: Mon Sep 12, 2011 10:40 am
I've got an idea to see if the lean is coming from the front or the back.
Post Posted: Wed Sep 14, 2011 9:14 am
If i don;t have one pan hard rod centered right, could that cause some of the lean? The front springs are running on a bit of angle, so much of a angle the drivers side fowls on the chassis when flexing :lol:.
Vehicle: 03 Jimny
Post Posted: Sat Dec 24, 2011 2:17 am
Hey monkey do you still have your lean.
Mine is very noticeable. Everything seems to be fine, springs etc.
Mine only got the lean after I installed the arms which is quite weird.
I cannot figure it out, I have no idea what it could be.
Post Posted: Sat Dec 24, 2011 3:22 am
Yep still got it :(
Close to 30mm on the drivers side, but it I put the drivers side td coil in with a stock front in the rear on the passenger side, the lean goes away :lol:
Vehicle: Sj70 tintop
Post Posted: Sat Dec 24, 2011 3:27 am
ive seen lots of jimnys lean.... some lean right onto there roof pretty often on this sight 8)
Sj70 tintop
Vehicle: 03 Jimny
Post Posted: Sat Dec 24, 2011 3:43 am
monkey wrote:
Yep still got it :(
So yours is 30mm higher on drivers side?
Post Posted: Sat Dec 24, 2011 4:29 am
30mm lower on drivers side...
Vehicle: 03 Jimny
Post Posted: Sat Dec 24, 2011 4:58 am
Same as mine. What I don't get is that it was perfect before the arms went in :?
Users browsing this forum: No registered users and 117 guests
