It is currently Sat Nov 07, 2026 12:17 pm
Post Posted: Mon Sep 12, 2011 7:22 pm
Hello everyone.
I'm new in here, I own 97 SJ80 and i live in israel.
My 1.3 engine gone bad.. and i want to upgrade my little coily to 1.6 with little fuzz as posibile.
I wonder if i can fit in 1.6 8v to use my oem TBI., simply bolt on.
I'll appriciate any help ..
Thanks,
Ori.
Post Posted: Mon Sep 12, 2011 9:15 pm
epitam wrote:
Hello everyone.
Thanks,
Ori.
You should be able to do exactly that. Previously I have used a 1.6 TBI injection manifold on a 1.3 and it was a bolt on job. I can't help you much on the ECU side though as I used an aftermarket ECU.
You'll want a 1.3 -> 1.6 conversion kit to make and easy job of bolting the gearbox up. Have a look in the vendor section.
Any other questions just shout out. Heaps of people have done the same thing (although not so many the injection).
Post Posted: Tue Sep 13, 2011 5:11 pm
Well, the conversion kit i know.. and thanks for your reply.
I'm happy to hear the manifold is bolt on.
now, how can i figure out if any other changes, the ecu or may be the wiring and conectors.. need to be modified.
I on low-tech side, help needed.
Post Posted: Wed Sep 14, 2011 1:15 am
Seeing you're re-using the original manifold there shouldn't be anything you need to do in terms of wiring modifications. The only thing I can think of at the moment is the exhaust manifold. Because the 1.6 block is slightly higher your head will sit slightly higher as well. This may mean that the exhaust doesn't line up properly with the manifold. It's probably something you'll just have to deal with as you get to it.
Users browsing this forum: No registered users and 85 guests
