It is currently Sat Nov 07, 2026 12:14 pm
Post Posted: Thu Sep 15, 2011 11:11 am
I am wondering about running a vitara 1.6 gearbox and transfer in a sierra with hilux diffs i have been trying to search for info on it and all i can find is ppl running the 1.6 gearbox and motor but not the transfer so any info would be good thanks
Post Posted: Thu Sep 15, 2011 11:14 am
it would put the tail shaft in the right spot for the diffs but gearing may be a issue.
Post Posted: Thu Sep 15, 2011 11:17 am
That is the main reason i wanted to run it so that i can just use a hilux diff in the rear and not have to try and find a bundy one
Post Posted: Thu Sep 15, 2011 11:18 am
The biggest issue is the height of the rear output. Your shaft will be coming from up near the floor. Usually the body mount cross member will get in the way, so you will need to laminate that and then cut the centre section out so the drive shaft can pass through.
If you have a LWB and cut the x-member as above, you will be laughing!
Run 4.88 yota centres, and get some 4.24 transfer gears and you'll be set.
Post Posted: Thu Sep 15, 2011 11:24 am
it will be going in a LWB it already has a 2'' body lift but the plans are for hilux diffs 4link rear 3link front and coilovers and maybe turbo
Post Posted: Thu Sep 15, 2011 11:28 am
Should work then. And if you need more gearing than the transfer and diffs can offer. Buy an undertaker!
Post Posted: Thu Sep 15, 2011 11:33 am
running hilux diffs it gives me lots of gearing options to play with
Post Posted: Thu Sep 15, 2011 8:10 pm
Anything bigger then 31 buy a undertaker
My mate runs 1.6 auto vit tc 5.29 hilux diffs and 36 in his Sierra and it sucks on road
Don't think it's ever been in forth
He's looking at the undertaker now
Post Posted: Thu Sep 15, 2011 9:24 pm
That should not be driven on the road. :roll:
Post Posted: Thu Sep 15, 2011 9:34 pm
He only got the 36
It was built and certified on 33
Post Posted: Thu Sep 15, 2011 9:43 pm
You also need to make slip yoke eliminators for the Vitara transfer case as they dont run output flanges, the tai shafts just slide in and out which is not suited for what your doing.
Post Posted: Thu Sep 15, 2011 9:44 pm
Nope. You just buy those from Lowrange :wink:
Post Posted: Thu Sep 15, 2011 10:34 pm
How about a kicker-3 / shogun box
Vit to sierra case doubler. 1-1 in high, 3 gear ranges to choose from.
Users browsing this forum: No registered users and 89 guests
