| Jim power steer to sierra https://auszookers.com/forum/viewtopic.php?f=5&t=26592 |
| Author: | JrZook [ Sun Oct 09, 2011 11:55 am ] |
| Post subject: | Jim power steer to sierra |
So it's ps time for me, hoping to finally get the sloppy sierra steering box and have non-glowing shoulders after a hard days wheel on 5psi. I have a jimny ps box, jim hardlines, vit pump and bracket (thanks MrFatz ). I also have the stock jim pump if I really need to use it, which would require a full custom bracket and more time/rum.
Who has installed this setup before? Any pics? Interested in seeing how you routed the hardlines or sorted them out. Will I run into any trouble with the steering shaft length? This is a non collapsible type. Cheers Dan |
| Author: | royce [ Sun Oct 09, 2011 7:54 pm ] |
| Post subject: | Re: Jim power steer to sierra |
why will the jimny pump not bolt into the bracket? ive got a jimny pump in mine youll need to sort the shaft out, the lines can sit along the front tube crossmember esy enough with a few tweaks |
| Author: | Rusho [ Sun Oct 09, 2011 9:15 pm ] |
Pretty sure you need the collapsable type steering shaft(coily's are useful for something You are getting new lines made up aren't you |
| Author: | JrZook [ Sun Oct 09, 2011 11:29 pm ] |
royce wrote: why will the jimny pump not bolt into the bracket? ive got a jimny pump in mine
youll need to sort the shaft out, the lines can sit along the front tube crossmember esy enough with a few tweaks It has totally different castings and doesn't match up to the vit bracket at all. Ill have to get a pic. So I will require a collapsible steering shaft? |
| Author: | Rusho [ Sun Oct 09, 2011 11:39 pm ] |
Collapsable shaft or some booty fab cut and shut work |
| Author: | JrZook [ Sat Dec 17, 2011 1:54 am ] |
So any body else run the jim box? Just after some pics of how you routed your HP and return lines. The stock jim lines are far from fitting so looks like I'll get something custom made up |
| Author: | 31zook [ Sat Dec 17, 2011 4:41 am ] |
i run mine, and NIK's jimny line's (aswell) infront of the radiator, i have a cooler on the return line, so it's stuck onthe radiator... dunno if that helps... |
| Author: | bagnkat [ Sat Dec 17, 2011 8:21 am ] |
JrZook wrote: So any body else run the jim box?
Just after some pics of how you routed your HP and return lines. The stock jim lines are far from fitting so looks like I'll get something custom made up Royce is right, it will fit across the tube cross member. I have done it as well. I used a pipe bender to put a bend in 'shortening' the overall length of the lines. If I can get some photo's tomorrow I will put them up. I also used a Vit pump like you intend to. |
| Author: | JrZook [ Sat Dec 17, 2011 11:14 am ] |
bagnkat wrote: JrZook wrote: So any body else run the jim box? Just after some pics of how you routed your HP and return lines. The stock jim lines are far from fitting so looks like I'll get something custom made up Royce is right, it will fit across the tube cross member. I have done it as well. I used a pipe bender to put a bend in 'shortening' the overall length of the lines. If I can get some photo's tomorrow I will put them up. I also used a Vit pump like you intend to. Pics of your setup would be great mate! Upon inspecting a factory PS setup on a Jimny I believe my line have been played with already and hence are wayy off from fitting atm |
| Author: | drovin [ Sat Dec 17, 2011 8:30 pm ] |
Im running the jimmy pump and box, made up adapter to plate to bolt up to a g16b as the brakets that came with the kit were from an M series . Pretty simple thing to do and a few tweeks on the lines here and there to get them to fit is no biggy. Works great and with a front lockfite makes life bearable. just!!! |
| Author: | bagnkat [ Sat Dec 17, 2011 8:33 pm ] |
Here's a photo of the lines running along the crossmember. The lower line has a few bends to get around obstacles, but neither line touches anything. I used some plastic clamps off a Vitara to secure the top line. The clamps clip onto the crossmember and secure the line about 1/4" off it. The lower line is held by P clamps / adele clamps. I couldn't get a good angle on the line heading to the pump / reservoir. It's really dificult to get a decent photo. If you want a specific area let me know and I'll try. I hope it helps
| Author: | steak_knife [ Sat Dec 17, 2011 10:19 pm ] |
Can you post a pic of looking down on the box please??? |
| Author: | bagnkat [ Sun Dec 18, 2011 12:52 am ] |
These are the best photo's I could get Stekky. There is plenty of clearance around the box, but too much crap obscurring the photo.
The other photo shows the difference between the two boxes. The geometries are all the same, just the input shaft extends more to allow for the power componentry.
As Rusho said, you need a collapsible steering shaft from a coily... No... you just need a coily |
| Author: | steak_knife [ Sun Dec 18, 2011 1:05 am ] |
Those top 2 should answer one of his question's, cheer's....
| Author: | BlueSuzy [ Sun Dec 18, 2011 1:12 am ] |
wt's use a collapsable shaft also. |
| Author: | bazook [ Sun Dec 18, 2011 5:46 am ] |
collapsable shaft is the way to go I just drilled the plastic pins out and slid the shaft to where i needed it, and booty fabed a braket for my g16b and ran the lines out side the chasis rail and up through the guard but thats soon to be fixed |
| Author: | JrZook [ Sun Dec 18, 2011 12:00 pm ] |
Thanks for the pics mate. They really helped out. Turns out I do have jimny lines but the have been bent and mutilated out of shape in there past life. No 180* bend existed on the hardline straight out of the steer box which had me stumped as to how it fit with minimal mods. Managed to bend up a mongrel reincarnation in which I shall use as a template to get some new lines made up. BlueSuzy wrote: wt's use a collapsable shaft also. Seems the 88.5 SWB WT did not have |
| Author: | mcwilly [ Sun Dec 18, 2011 5:39 pm ] |
So if the power steering comes off a g13bb jimny engine all the jimny brackets etc should bolt straight on to the g13ba engine. However the problem occurs when it comes off a M series engine? Or if you have a g16b it's better to go the vit power steering with bent kit |
| Author: | 31zook [ Sun Dec 18, 2011 6:32 pm ] |
yep chris |
