https://auszookers.com/forum/
removing bush
https://auszookers.com/forum/viewtopic.php?f=5&t=2672
Author:  Mike [ Wed Aug 06, 2008 3:01 am ]
Post subject:  removing bush
what is the best way to remove those pressed in rubber bushes with metal sleeves?
Author:  BlueSuzy [ Wed Aug 06, 2008 3:03 am ]
Post subject:  Re: removing bush
Big F Hammer, Or a press :wink:
Is it torn?
Author:  Mike [ Wed Aug 06, 2008 3:07 am ]
i tried the hammer took a chunck out of my driveway doing it :roll:
its not torn but i got nolothane bushes on the other side
Author:  BlueSuzy [ Wed Aug 06, 2008 4:01 am ]
Probably better to just leave to bush in...Better for flex but depends how stiff your new bushes are.. :?
I had nonthane with my kingsprings. But im just using the stocko rubber ones now as i fixed my wobble problem..
Rubber are meant to be flexier
Author:  royce [ Wed Aug 06, 2008 11:03 am ]
carve as much of the rubber out as you can then get a chisel into teh gap where the spring eye wraps around and smash the outer sleeve in to collapse it
or leave the sleeve behind and burn the rubber out, the nolathane bushes will still fit
Author:  Scrawny [ Wed Aug 06, 2008 11:41 am ]
:twisted: :twisted: :twisted:
This has always been the best way I've found 8)
Author:  sp1086 [ Wed Aug 06, 2008 9:35 pm ]
Bit smelly though :gross:
Author:  Mike [ Wed Aug 06, 2008 11:49 pm ]
whats the best way to burn them out? :twisted:
Author:  royce [ Wed Aug 06, 2008 11:55 pm ]
fire :)
Author:  Mike [ Thu Aug 07, 2008 12:00 am ]
what sort of excelorents should be used?
Author:  Geepee [ Thu Aug 07, 2008 12:02 am ]
a bit of WOOF (petrol) hahahaha
Author:  Mike [ Thu Aug 07, 2008 12:07 am ]
wouldn't it be bad for the string to get too hot?
Author:  royce [ Thu Aug 07, 2008 12:25 am ]
nah the string will get hammered but its ok you dont need string in your suspension :wink:
Author:  Mike [ Thu Aug 07, 2008 12:26 am ]
what if the spring gets hot :lol:
Author:  royce [ Thu Aug 07, 2008 12:27 am ]
you wont get it that hot its only burning rubber
Author:  Mike [ Thu Aug 07, 2008 12:29 am ]
so burn it out with petrol and leave the ring in there? :lol:
Author:  royce [ Thu Aug 07, 2008 12:40 am ]
youd probably be better going to bunnings and grabbing a gas torch thingy for $25 to do it, will come in handy later too
Author:  Mike [ Thu Aug 07, 2008 1:01 am ]
just in case i need to burn something else?
Author:  Zook_Fan [ Thu Aug 07, 2008 1:17 am ]
you never know when insurance money can come in handy :D
