It is currently Sun Oct 18, 2026 11:46 pm
Post Posted: Mon Aug 18, 2008 11:46 pm
Hi guys,
My car battery nearly dead I think. If I dont use the car for few days I can feels like the car strugling to start. I did recharge it but still the same. Before I get it replaced I was just wondering whether it worth to ask the garage like Bob Jane etc to service the battery. Cheers.
Post Posted: Mon Aug 18, 2008 11:53 pm
check your terminals are clean and if you have a mulimeter that the alternator is working properly, otherwise its fair to say its getting on and needs replacing
if you dont use the car a lot it might be worth getting a little maintainence charger to keep it charged and in good nick
Post Posted: Tue Aug 19, 2008 12:03 am
Go with what Royce suggested, make sure the terminals are clean and tight. Also check fluid levels, all the lead should be covered. Don't fill right to the top though :lol:
Batteries usually only last 4 years so if it about that age then look at replacing, should be less than $100
Post Posted: Tue Aug 19, 2008 12:29 am
Well I think its already more than 4 years old. Better replace it then.
Post Posted: Tue Aug 19, 2008 2:27 am
If you get 4 years out of a battery you're doing well. although a lot of the better ones at least have a 3 year warranty on them now. If you take it to a garage, the most they will do is a load test and if they're really looking after you they'll do a specific gravity reading on each of the cells, and will advise you you will require a new battery. Apart from cleaning the terminals and putting a little water in the battery (if it's not a sealed unit), there is really nothing you can do to 'service' a battery.
Post Posted: Tue Aug 19, 2008 10:12 pm
yer what he said :twisted: :twisted:
Users browsing this forum: Google [Bot] and 450 guests
