https://auszookers.com/forum/
Heellpp!?!?
https://auszookers.com/forum/viewtopic.php?f=5&t=28210
Author:  stocker [ Thu Dec 01, 2011 5:41 am ]
Post subject:  Heellpp!?!?
Hey guys and girls...
So my problem is just this...
Put the new front diff in yadda yadda yadda... No problems there
Then *insert dramatic music here* came the test drive...
Placed in 4wd high go for a spin down the block. under
Acceleration front end lifts up and the back end Boggs down
The only thing I can think of is that the diff ratio is wrong...
But... I am sure the wrecker counted the teeth right not only
In front of me but imam sure As hell I counted them right...
8 teeth on pinion 41 on the crown... Any ideas???
Author:  atari4x4 [ Thu Dec 01, 2011 6:23 am ]
Post subject:  Re: More crappy diff help...
jack the back up & check the rear diff ratio... maybe you don't have 512's. 8O
did you check the one that came out?
Author:  steak_knife [ Thu Dec 01, 2011 7:06 am ]
& don't select 4wd till you have the same ratio front & back again.....
Author:  stocker [ Thu Dec 01, 2011 7:23 am ]
Shit bugger bitch bum... Just counted the output of the cv's vs drive shaft... By the look of it now I have roughly a 4.9 ratio... Will call the wrecker 2morro but I'm not holding my breath... Does anyone have another 5.125 center with 26 spline axles???
Author:  stocker [ Wed Dec 14, 2011 8:25 am ]
Sorry to Rehatch Old Egg's guys, but i still need a 26 Spline 5.125 Front Diff Center to get my zookie going...
Author:  atari4x4 [ Wed Dec 14, 2011 8:28 am ]
what about the one from the wreck you bought & just run a 22 spline RHS CV?
Author:  stocker [ Wed Dec 14, 2011 8:29 am ]
isn't the 26Spline Much stronger? I am running 31's now...
Author:  atari4x4 [ Wed Dec 14, 2011 8:39 am ]
i ran a 22 spline inner for a year or more on 31's before building up the steel diff with the RD88 (26spline) locker, never broke it but i'm not a throttle jockey. :wink:
Author:  stocker [ Wed Dec 14, 2011 8:40 am ]
hahaha... well since i whacked the 31's under mine, i haven't been anywhere near as rough on mine.... i will change the 22spine one into mine then :)
Author:  stocker [ Tue Dec 27, 2011 10:38 pm ]
Ok so the finger got pulled out of my butt
And I ripped the front diff out to find that it is the right ratio diff 41 teeth on the crown wheel an 8 teeth on the pinion...
So to keep you all up to date on what's been done...
I fixed the manual locking hub. Replaced the diff. And now the drive line loads up in 4wd.
...help
Author:  stocker [ Wed Dec 28, 2011 2:38 am ]
Post subject:  Re: Heellpp!?!?
Bump!!!
Author:  stocker [ Wed Dec 28, 2011 2:40 am ]
Just pulled the rear it is also a 5.125 taro with 41 teeth on the crown and 8 on the pinion
Author:  shep [ Wed Dec 28, 2011 2:48 am ]
did ya do a timbo and put the front diff in upside down?
Author:  atari4x4 [ Wed Dec 28, 2011 3:43 am ]
what ratio was the one you broke?
EDIT: just saw that you've pulled the rear diff to find it was also 512:1
are you running the same size tyres front & back? :?
Author:  Chop [ Wed Dec 28, 2011 3:46 am ]
That was my next guess, different tyre size?
Author:  stocker [ Wed Dec 28, 2011 8:48 pm ]
Hey guys you physically cant put the front diff upside down due to the mount on the pinion.
Definitely got the same size tyres front and back 31x11.5r15
Author:  stocker [ Thu Dec 29, 2011 12:56 am ]
Was just thinking it might be binding up between 4wd hi & low...
Has anyone had this problem with the vitara transfer case???
