| Disconnecting warning beeper 2001 Jimny https://auszookers.com/forum/viewtopic.php?f=5&t=28475 |
| Author: | OMalley [ Fri Dec 09, 2011 8:51 am ] |
| Post subject: | Disconnecting warning beeper 2001 Jimny |
Is there a way to disconnect to the beeper/warning tone that goes off whenever you have left the lights on or when the keys are in the ignition and the door is open? It makes listening to the radio with the door and car turned off impossible, and is a painful sound anyway.. thanks in advance guys! |
| Author: | monley [ Fri Dec 09, 2011 9:03 am ] |
| Post subject: | Re: Disconnecting warning beeper 2001 Jimny |
Turn the music up louder
| Author: | steak_knife [ Fri Dec 09, 2011 9:15 am ] |
Find said beeper & drill a small hole through the center of the speaker, if you cut wire's other thing's will play up.. Or, you can pull the wire off the driver's door light switch, but, other thing's will play up... |
| Author: | atari4x4 [ Fri Dec 09, 2011 9:21 am ] |
wind the windows down & close the doors when listening to music? i like my buzzer, saved me from leaving the lights on a few times |
| Author: | TZAR [ Fri Dec 09, 2011 10:25 am ] |
| Author: | TZAR [ Fri Dec 09, 2011 10:26 am ] |
or get shep to weld something on the car |
| Author: | 89_tintop [ Fri Dec 09, 2011 10:46 am ] |
TZAR wrote: or get shep to weld something on the car
Hahahahahahahahahaha ............. .................... .... ....... Burn |
| Author: | banga [ Fri Dec 09, 2011 6:12 pm ] |
atari4x4 wrote: wind the windows down & close the doors when listening to music?
i like my buzzer, saved me from leaving the lights on a few times mine doesn't beep quick enough ive left the lights on once or twice after driving subarus for 6 or so years (they turn them off for you) you forget to turn them off. |
| Author: | steak_knife [ Fri Dec 09, 2011 6:52 pm ] |
Find said box & unplug, I seam to remember doing that one day when it was shitting me, had my head under the dash for a while with ing on. Just make sure all light's & shit still work tho.. |
| Author: | OMalley [ Sat Dec 10, 2011 10:58 am ] |
steak_knife wrote: Find said box & unplug, I seam to remember doing that one day when it was shitting me, had my head under the dash for a while with ing on.
Just make sure all light's & shit still work tho.. Thanks Stekky, I shall go for a hunt tomorrow morning. Hopefully I'll find the source of it before it drives me up the wall.... |
| Author: | OMalley [ Sat Dec 10, 2011 11:01 am ] |
i like my buzzer, saved me from leaving the lights on a few times Im not a fan of buzzers. It can run flat |
| Author: | foolsp33d [ Sat Dec 10, 2011 12:36 pm ] |
http://www.suzuki-forums.com/suzuki-jim ... moval.html maybe!? |
| Author: | alien [ Sat Dec 10, 2011 12:38 pm ] |
can you not find it, then fit a switch to it? so when it annoys you, you can turn it off... otherwise you can leave it on to do its job =) |
| Author: | Total_Filth [ Sat Dec 10, 2011 1:10 pm ] |
My interior light doesn't turn on when I open the drivers door and I don't have a beep when the lights are left on... I wonder if my switch is disconnected.... mmmmmm TF |
| Author: | alien [ Sat Dec 10, 2011 1:11 pm ] |
my interior light in the sierra only works when i clean the contacts in the switch.... it works for about a month then gets corroded again and stuffs up. |
| Author: | steak_knife [ Sat Dec 10, 2011 10:48 pm ] |
Total_Filth wrote: My interior light doesn't turn on when I open the drivers door and I don't have a beep when the lights are left on... I wonder if my switch is disconnected.... mmmmmm
TF Not all jim's have the lil annoying box...... |
| Author: | TZAR [ Sat Dec 10, 2011 10:53 pm ] |
steak_knife wrote: Total_Filth wrote: My interior light doesn't turn on when I open the drivers door and I don't have a beep when the lights are left on... I wonder if my switch is disconnected.... mmmmmm TF Not all jim's have the lil annoying box...... zookylizs does
| Author: | Bugsta [ Wed Dec 21, 2011 11:34 am ] |
I pulled my instrument cluster out and removed the little buzzer from the holder. Didn't take me that long either. Just a few screws and a small flat blade. |
