It is currently Sat Nov 07, 2026 10:03 pm
Post Posted: Sat Dec 10, 2011 9:41 pm
driving around the other day and the car wouldn't start it had fuel and battery volts are up, it would turn over it just wouldn't fire, it has new plugs(500km) old would anyone say starter relay or starter it self..????
Post Posted: Sat Dec 10, 2011 9:47 pm
pull the fuel line off the carby and see if any squirts out when you turn the key.
Post Posted: Sat Dec 10, 2011 10:05 pm
Ok...
1st off .. What car is it? What engine is in it? Efi or carby
Check that you,have a strong spark at the leads, if you dont check for it at the coil lead on the dizzy (assuming you have a car with a dizzy)
Check for fuel (either at the carby or fuel rail) if not start tracing it back. Once again the method will change from efi to carby cars
If both of these are ok then next would be to check for compression.
if there Is no or low compression then you have to figure out why..
But lets start to see what you have and dint have.
It sounds like it is turning over, going by your post,
So
Car turns over ??
Car has fuel in it (i am assuming you just mean in the tank and have not looked for whether it is up at the carby/injector rail)
New pkugs fitted (500klms ago)
Post Posted: Sun Dec 11, 2011 3:28 am
yeah 89 tin top that is it ill check for fuel coming up to the carby and see wat happens, yeah sorry guys it's a 90 model wt Sierra with a g13
Post Posted: Sun Dec 11, 2011 3:32 am
So have you checked any of the above?
Vehicle: Sj70 tintop
Post Posted: Sun Dec 11, 2011 4:04 am
if she turns over, ya starter motor is good, you need to do the above to isolate if its a spark or fuel problem, than you can go from there.
Sj70 tintop
Post Posted: Sun Dec 11, 2011 4:36 am
ok well just went down and checked it, i took the fuel line off that lead to the carby no fuel came out til it actully ran and also checked for spark and had a good spark from the coil...
Post Posted: Sun Dec 11, 2011 4:37 am
Post Posted: Sun Dec 11, 2011 5:19 am
Yeh.. Fuel wont come out of that hose till engine is turning as it is a mechanical pump which is run off the camshaft.
At what point did u check for spark? At a spark plug lead or coil lead?
Post Posted: Sun Dec 11, 2011 5:20 am
If you turn the key, which makes the starter motor work, which turns the motor over which activates the mechanical fuel pump, fuel will come out. If thats not happening there's your problem.
Post Posted: Sun Dec 11, 2011 5:34 am
ok so it's not fuel,..... aahhhhhhh stupid car....
Post Posted: Sun Dec 11, 2011 6:50 am
pull the plugs out and have a look. Aldo where were u checking spark.
Users browsing this forum: Google [Bot] and 84 guests
