Vehicle: Suzuki Vitara - 2016
Posted: Mon Aug 22, 2016 12:51 am
Hi inhere.. I'm new here but have a question:
my horn dosen't work and to get to it I have to remove the radiator grill on grand vitara model 98-05? but how? there are 4 screws in the top, but with them removed it is still "fastned" in the bottom.... what to do?
There should be four plastic clips at the top (not screws) and five plastic friction fittings at the bottom - remove the clips (or screws) from the top and then gently pull the bottom forwards - the clips are, one in the center, and two each, under the headlights, with the two outer ones at the extreme end.
Users browsing this forum: Google [Bot], Teddymt and 201 guests
