https://auszookers.com/forum/
wiring chinasoong compressor
https://auszookers.com/forum/viewtopic.php?f=5&t=28731
Author:  swifty_ano [ Sun Dec 18, 2011 6:32 am ]
Post subject:  wiring chinasoong compressor
Hi guys,
Some of you may know that I bought a Chinasoong locker. Now my expertise is minimal. I have no idea when it comes to dc wiring.
I am trying to wire up my compressor but failing.
Here is the diagram I was supplied
However, chinasoong switches are different. They only have 4 terminals on the back.
Can I get by without buying an arb genuine?
Heres my problem. I have no idea which terminal is which on the switch.
So I don't know which terminal to put the black wires on? Which one to put the red on?
I have also hooked the red-yellow wire to ignition (cd player circuit) 20 amp (compressor inline fuse is 30a). Everytime I turn the key its blowing the cd player fuse.
There are no wires earthing to the frame.
I'm thinking excess current draw is the problem?
The odd thing is, I can't hear of feel the compressor kick in before the fuse blows.
Please don't laugh at my stupidity :)
Author:  royce [ Sun Dec 18, 2011 6:37 am ]
Post subject:  Re: wiring chinasoong compressor
what wires do you need to hook up and what colours are they?
what wires do you have at the switches?
somebody that knew any wiring would know a good start would be get a meter and figure the switch out :wink:
Author:  swifty_ano [ Sun Dec 18, 2011 6:41 am ]
Usually i would. But I don't have a meter here. I'll take it to work and find out the terminals.
Author:  swifty_ano [ Sun Dec 18, 2011 6:42 am ]
At the isolator switch I have 2x black, 1x red 1xred-yellow and 1x blue-white
Author:  zooky08 [ Sun Dec 18, 2011 6:45 am ]
Hook your wire to acc onto the key barrel not you cd player.
If your switch has 4 point I'm guessing two black wires go to 3 and 4
Yellow and red either goes to 1 and 3(swap around till compressor work)
Arb harness has labels on there's so I assume chinasoong ones don't?
Edit: on the back of your switchs is thee numbers?
If so
Black wires to 7 $ 8
White and blue to 6
Red and yellow to 3
Red to 2
But as you said you oy have four pins so Idk no what's the go there :?
Author:  royce [ Sun Dec 18, 2011 6:53 am ]
and 4 spots on the switch?
does the terminal layout on the switch look like above but minus a spot for a black wire?
Author:  swifty_ano [ Sun Dec 18, 2011 7:00 am ]
Nope. No numbers on the back.
It just has 4 terminals on the back. They are four corner layout
Author:  royce [ Sun Dec 18, 2011 7:02 am ]
hook up red and red yellow and no others to a pair and see what you get, move em around till you get some switch action, then try adding an earth to one of the remaining to see if you get some light up when you turn it on then try adding the blue to see if it will light up with dash lights
Author:  swifty_ano [ Sun Dec 18, 2011 7:33 am ]
will do. Cheers royce.
Whilst I am here, how do I hook up the red-yellow to the barrel?
is it ok to mount the compressor under a seat on its side? bloody thing wont fit anywhere.
Author:  reallyuted [ Sun Dec 18, 2011 7:44 am ]
just had the same problem with a mate's one red and yellow both go on 1 side of the switch red at top then blue with white trace next to yellow and black next to red. after a heap of emails to them they still could not tell me how to wire the incorrect switch
PRETTY SURE THIS IS HOW I WIRED IT
back of switch
NO TAB NO TAB
RED _ _ BLACK
YELLOW _ _ BLUE/ WHITE
ONE BLACK LEFT OFF
Author:  royce [ Sun Dec 18, 2011 7:48 am ]
if they red yellow is just the ignition trigger it it ok to go from the radio, its only switching a relay and solenoid, I reckon you were shorting it hooking the switch up wrong
you can with an ARB, mines on its side behind the seat
Author:  swifty_ano [ Sun Dec 18, 2011 7:53 am ]
Excellent. Cheers guys.
Ilk get it sorted tomorrow. Try and take pictures for future reference.
Author:  swifty_ano [ Mon Dec 19, 2011 6:30 am ]
Ok the combination REALLYUTED gave me worked a treat.
Works a charm now. Thanks very much for all the help.
By the way...im an Apprentice Electrician :D how shameful!
however, without a meter it was hard......well thats my excuse ;)
here is a picture of the back of the switch
Author:  neofitou [ Tue Dec 20, 2011 1:27 am ]
those are both the same picture..
