It is currently Sun Nov 08, 2026 3:57 am
Vehicle: 03 Jimny
Post Posted: Sun Dec 18, 2011 6:26 pm
My Jimny has a cracking noise around the radius arm/ shock mount on the rear diff.
Could be inside the diff or around that area as far as I can hear.
It's when I drive on bumps or anything that rocks my car.
Car doesn't need to be moving, does it while it's parked and I rock the car.
Ive check all bolts they are tight. Springs are sitting right. Rubbers are good.
Vehicle: 75 Cruiser
Post Posted: Sun Dec 18, 2011 6:50 pm
Have you been flexing it?
Maybe it's cracked the diff brackets?
Maybe it's just mud that got in to the bushes and you need to pull it all apart and clean it up?
Maybe Coil noises?
Vehicle: 03 Jimny
Post Posted: Sun Dec 18, 2011 7:15 pm
Yes I flexed it one afternoon and it started making the noise after it.
I've had a good look and I can't see any of the welds cracked.
It's not the usually Jimny crack noise when flex it up, it's much worse.
Cracks when the car moves side to side or when ever the diff moves up and down.
Vehicle: 75 Cruiser
Post Posted: Sun Dec 18, 2011 7:19 pm
Checked the panhard rod brackets, chassis bracket and diff bracket?
Vehicle: 03 Jimny
Post Posted: Sun Dec 18, 2011 7:29 pm
Panhard brackets are good. I put my ear down to the diff and I can here it around the radius arm bracket or in the diff, or it could be ekoing from somew where else?
Post Posted: Sun Dec 18, 2011 7:39 pm
Is it the coil
Try rotating it back away from the step in the seat
Vehicle: 03 Jimny
Post Posted: Sun Dec 18, 2011 7:46 pm
got_bar_work wrote:
Is it the coil
Yea coils is around a inch away from the step
Post Posted: Sun Dec 18, 2011 8:32 pm
my body lift bolts come loose sometimes, thney do similar noises
Vehicle: 03 Jimny
Post Posted: Sun Dec 18, 2011 8:37 pm
I'm 100% sure it's in the diff or around the radius arm bracket, as I rock the car with my ear down near the diff.
Post Posted: Sun Dec 18, 2011 9:28 pm
wheel bearing?
Vehicle: 03 Jimny
Post Posted: Sun Dec 18, 2011 9:53 pm
alien wrote:
wheel bearing?
Every single bearing got replaced in the diff a month ago
Post Posted: Sun Dec 18, 2011 11:10 pm
have you jacked the wheels off the ground to check? could even be loose wheel nuts.
Vehicle: 03 Jimny
Post Posted: Mon Dec 19, 2011 12:29 am
I'll have alook when I get home from work.
Ill take the hole drum off and have a look as well
Vehicle: 96 sj70+80 tintop sierra
Post Posted: Mon Dec 19, 2011 1:06 am
Check your bolts that hold arms in place, I had same noise and ended up being chewed out bolts allowing arm to move. Lay under car and see if arm moves. If u replace the bolts make sure u use spring washers and loktite as they will work loose in no tine at all.
Adam
Post Posted: Mon Dec 19, 2011 3:26 am
my arms were doing the same thing and i was advised to tighten the shit out of them and it worked.
Vehicle: 03 Jimny
Post Posted: Mon Dec 19, 2011 3:45 am
Okay so I found the problem. Bottom shocky bolt was a tad loose causing it to warn/stretch the metal bush inside.
So bolt was hitting the bush when diff went up and down.
Put new bush in and Tighten it right up and no noise now :D
But now I seen that my radius arm bushes are fecked :(
Cheers guys
Post Posted: Mon Dec 19, 2011 3:47 am
I loves a happy ending :)
Post Posted: Mon Dec 19, 2011 5:22 am
Cheers guys
Was going to say, loosen & re tighten all suspension bolt's.....
Vehicle: 03 Jimny
Post Posted: Mon Dec 19, 2011 5:41 am
Well I snapped one shocky bolt, lost one, and now this one came loose with a months driving.
I think I need a spring washer or some locktite in there.
Post Posted: Mon Dec 19, 2011 5:43 am
Please go the spring washer....... or Nylock's...
Vehicle: 03 Jimny
Post Posted: Mon Dec 19, 2011 5:53 am
It's a bolt so spring washer it is
Users browsing this forum: No registered users and 128 guests
