https://auszookers.com/forum/
Sierra front diff not working
https://auszookers.com/forum/viewtopic.php?f=5&t=28821
Author:  Daves4wd [ Tue Dec 20, 2011 7:09 am ]
Post subject:  Sierra front diff not working
Hey all, took it for a test run today and my front isn't working the hubs are cold just wondering what it could be?? And anyone willing to help me this week sometime to get it working?
Author:  31zook [ Tue Dec 20, 2011 7:17 am ]
Post subject:  Re: Sierra front diff not working
cold or not working in 4wd?
never thought i would type that.....
Author:  Gwagensteve [ Tue Dec 20, 2011 7:40 am ]
So much confusion....
Have another go at that post Dave. Hubs get hot regardless of being driven or not.
Steve
Author:  zooky08 [ Tue Dec 20, 2011 7:53 am ]
Did u pull your diff apart to seeif your axles and cvs are broken :roll:
Author:  Daves4wd [ Tue Dec 20, 2011 11:03 am ]
Hey guys all fixed it was dry hubs sorry about my blabbering seems to be getting the better of me
Author:  DAZOOK [ Tue Dec 20, 2011 11:44 am ]
Dodgy.. ;)
Author:  joel [ Tue Dec 20, 2011 8:19 pm ]
dry hubs? so when you locked them they didnt engage?
damn get some grease in there 8)
Author:  Daves4wd [ Tue Dec 20, 2011 10:28 pm ]
All done Dazook helped me do it I'm going to ve doing a bit more testing tonight see how it goes
Author:  Daves4wd [ Tue Dec 20, 2011 10:31 pm ]
How can you tell your getting a switched one liter case?? Is the hand brake on the back of the back of the case?? Cheers off topic but not worth starting a new thread
Author:  tanshi [ Tue Dec 20, 2011 10:39 pm ]
a switched case has a 4x4 switch, a non switched one doesnt
Author:  Daves4wd [ Wed Dec 21, 2011 1:00 am ]
I'm guessing I answered my own question then
Author:  303zuke [ Wed Dec 21, 2011 1:59 am ]
But he didn't clarify how to tell if it's a One Litre switched case!
Put the case into low range and turn the brake drum one full rotation, and count how many times the Input flange turns while you do it. It helps if you put a Texta or chalk mark on both the drum and flange before you start.
A 1.3 case will turn the Input 2 and a quarter times, while a 1.0 case will turn it 2 and a half times. If your mark on the flange is 180deg from where you started, it's a 1.0 case, if it's 90deg then it's a NT 1.3.
Author:  Daves4wd [ Wed Dec 21, 2011 2:08 am ]
Ok awesome as thank you very much for that detailed way off telling 303zook other wise u wouldn't of guessed it
