On my current build im going to be running what could be alot of sticks,
i.e dual transfers
rear rear disconnect.
probably front disconnect aswell
i will also have a manualised AW4 auto so depending on how i do it there may be a stick for that too.
Ideally i would like to do away with as many sticks as i can and just have them switch operated. some of them i will not even be abvle to run full length sticks due to space constraints.
My question is what are people using or have seen used instead of running full gear sticks,
I have seen home made pneumatic rams used as well as electronic actuators.
from what i can find actuators cane be very expencive. Are there any cheaper options out there?
Users browsing this forum: No registered users and 151 guests
