It is currently Sun Nov 08, 2026 8:12 am
Post Posted: Fri Dec 23, 2011 11:06 pm
put a new clutch in the sierra and now the clutch is perfect! engages n disengages properly.. but it feels like my foot is going to go through the firewall everytime i change gear! there is just minimal pressure. is this ok? how do i adjust it
If in doubt power out!
Post Posted: Fri Dec 23, 2011 11:29 pm
if it works fine leave it enjoy your new light clutch you will get used to it
 Profile YIM
Post Posted: Fri Dec 23, 2011 11:40 pm
Did you put a standard clutch back in it? My sierra clutch was heavyish untill i swapped it for a stock one. Then it was light and very easy to drive.
Heavy clutches are a PITA in a cable setup. You just end up snapping clutch cables all the time. I dont think a sierra needs a HD clutch when they as such a small light car.
Post Posted: Fri Dec 23, 2011 11:43 pm
Leave it.
Post Posted: Sat Dec 24, 2011 1:13 am
Yeah it's just a standard replacement , it's definitely taking some getting used to. I'm leaving it just didn't no if it was how it's spose to be
Post Posted: Sat Dec 24, 2011 1:51 am
I did the same thing. It's normal mate
Post Posted: Sat Dec 24, 2011 2:32 am
X2
Because its new the fingers on the pressure plate sit flatter therefore the clutch becomes lighter.
SS
Users browsing this forum: No registered users and 126 guests
