It is currently Sun Nov 08, 2026 8:12 am
Post Posted: Sat Dec 24, 2011 2:54 am
Hey all i remember seein a HOW TO change rear axel bearings and oil seals.....cant find it though.....
Was i dreaming it?
I need it!haha
back in a built sierra!
Vehicle: 03 Jimny
Post Posted: Sat Dec 24, 2011 3:04 am
I cant find it either :(
Here is a bit of info from weaves
weaves wrote:
To get them off, cut the outer ring of the bearing off, take the balls off, this should allow the backing plate for the brakes to slide over and off.
Grab a cold chisel and a cutting disk, cut the locking ring almost through on each side, and smack it with the cold chisel a few times and it should break away and slide off.
the inner ring of the bearing is all that should be left, and you should be able to tap that off with the chisel and just tap it along the shaft as it shouldn't be extremely tight on the shaft.
assemble in reverse, and remember to put the backing plate for the brakes back on before the bearing.
weaves
Post Posted: Sat Dec 24, 2011 3:22 am
righto! im gunna look on the net....i have done it before years ago....but the bloke that usually helps is away fro chrissy! if i find one with photos i will let ya know!
Post Posted: Sat Dec 24, 2011 4:26 am
http://auszookers.com/index.php?name=Fo ... el+bearing
Post Posted: Sat Dec 24, 2011 5:14 am
Cheers bloke ya a gun! 8)
Users browsing this forum: No registered users and 126 guests
