It is currently Mon Nov 09, 2026 4:37 pm
Vehicle: yellow 83 sierra
Post Posted: Sat Dec 24, 2011 4:31 am
hi im looking at buying a sierra with the 1.3L engine in it.
the 1.3 is on gas but i was thinking i have a 1.6 block laying around how much effort would it be to put the 1.6 in but keeping the 1.3 head and gas on it? if i do do this i would be putting the vitara's 3 spd auto and transfer case in it as well. so what is required in this conversion?
Post Posted: Sat Dec 24, 2011 5:00 am
Swapping in the 1.6 is as easy as fitting the BenT or Petroworks kit and away you go.
Why bother putting a 1.3 head on the 1.6?
Vit box will bolt to G16 but the rest of the install is a shitfight.
The floor/tunnel will need major mods.
New crossmember will need to be made.
Then there is the big problem...... Vit transfer has a centre rear output whereas Sierra is offset to drivers side.
Post Posted: Sat Dec 24, 2011 5:55 am
hmm sounds like it would be easier to no bother would the standard 1.3 box bolt up to the 1.6? the only reason why im thinking this is that i have a 1.6 block (heads no good) and a 3spd auto both came out the vitara i bourght a little while back
Post Posted: Sat Dec 24, 2011 6:00 am
If you buy an adapter kit you can bolt the G16 to the Sierra gearbox.
The other option is to run the Vit auto with a blanking plate back to a Sierra transfer.
I think Joeblow makes a blanking plate.
Post Posted: Sat Dec 24, 2011 7:48 am
ok cool thanks i might keep that in mind
Post Posted: Sat Dec 24, 2011 8:45 am
Just go a straght g16 into it better off after you do all the mucking around the power increase isn't much
Post Posted: Sat Dec 24, 2011 9:29 am
yeh i might only change it if the motor dies you know it runs fine now would be good though 1.6L efi with an auto behind it :D
Post Posted: Sat Dec 24, 2011 10:25 am
That would be good but you need a engerners cert for injection and you don't for a carb that's one reason why I went a crab 1.6 plus I didnt have the cash for a g16b can't complain about the carb 1.6 I sit on 100 with 30s and standard gearing so it's about 110 115 kmh witch is a big increase and I need to reco the carb so it runs out of legs after 4000 rpm due to lack of fuel feed hahaha
Post Posted: Tue Jan 10, 2012 10:16 am
does it make much of a difference putting the 1.3 head on the 1.6 block?
Vehicle: 03 Jimny
Post Posted: Tue Jan 10, 2012 3:37 pm
I had this in 2 of my Sierra, yes there's noticeable power increased, but be far better to fit a g16b and be done with it.
Users browsing this forum: No registered users and 122 guests
