It is currently Sun Nov 08, 2026 8:08 am
Post Posted: Sat Dec 24, 2011 11:25 pm
Hey got carby problems I think.... it idles but won't rev any ideas how to fix this I'm in the middle on where! Thank you...
Post Posted: Sat Dec 24, 2011 11:32 pm
clean the fuel filter first, then check plugs,dizzy and leads.
Post Posted: Sun Dec 25, 2011 12:08 am
Does it back fire, stall, bog down????
Post Posted: Sun Dec 25, 2011 1:48 am
It stalls when I try to rev.. Fuel Im doing now but spark is good!
Vehicle: 95 sierra 1.3L / 95 GTI Sierra
Post Posted: Sun Dec 25, 2011 2:23 am
have you check your accelerator cable is attached properly and has tension?
Also check the accelerator arm and pump on the carby
I'm pretty new to this myself so maybe someone else will have better suggestions, but this is where I would look first
Post Posted: Sun Dec 25, 2011 4:08 am
I've had that before. Clogged jet.
Try swapping ignition leads 2 and 3 start it and rev up a little bit till you hear a couple of pops. Put the leads back and see how it goes. After that new fuel filter and add another filter before the carb.
Post Posted: Sun Dec 25, 2011 8:36 am
Ok thanks for ur help I will try tomorrow . Lol had to flat tow it out.
Post Posted: Sun Dec 25, 2011 8:47 pm
Exhaust blocked?
Air cleaner/intake blocked?
Post Posted: Mon Dec 26, 2011 10:40 am
Hey that worked thanks again man... Now I have a hole in my tank and the fuel was shit as... It was near brown!!! Haha
Users browsing this forum: No registered users and 138 guests
