Page 1 of 1
[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
DJB4x4
Joined: Thu Oct 06, 2011 9:02 am Posts: 25 Location: Murwillumbah
 Posted: Sun Dec 25, 2011 6:21 am |
ok i'm not sure how much lift is in my car??? i know that they are "king springs" (leafs) i'm pretty sure it is 3 inch because i dont think they make a 2 or a 1 inch lift. but besides the point i need new shocks and dont know what to order and wheres cheap. lowrange sells the old emu and doetsch but i dont know which is going to bolt straight in.
thanks heaps
Joshyboy26
Joined: Thu Sep 01, 2011 11:48 pm Posts: 814 Location: kinglake, VIC
 Posted: Sun Dec 25, 2011 6:38 am |
Take the shocks out that you have in it. Flex it up. Measure the distances between the mounts. Go to repco or peddars etc. Tell them what you need theyll give u it. I think i ended up with navara shocks and some random ones it all depends on your height and droop etc.
_________________ I love lamp
Built4thrashing
Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
 Posted: Sun Dec 25, 2011 6:42 am |
What shocks to get???????
Well unless you have put extended bumpstops in you will have to stick with stock ones. Otherwise when it compresses it will just snap the mounts off and possibly rip open the side of the chasis.
_________________ B4T
Bugsta
Joined: Fri Oct 30, 2009 10:30 pm Posts: 1754 Location: North Brisbane
 Posted: Mon Dec 26, 2011 1:39 pm |
That is only true of the compressed length pf the shock is longer than full compression of the spring.
_________________ If you can read this, please tip me back over
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Mon Dec 26, 2011 7:11 pm |
Bugsta, that's only true of coil springs. I'm going to assume from the post that the OP has leaf springs, in which case there's no real "compressed" data - they will keep compressing until they bend and bumpstop placement is critical.
In any case, only Calmini think it's OK to use the compressed length of a coil spring to prevent shock bottoming. The rest of us call that "coil bind" which is unacceptable.
Bugsta
 Posted: Mon Dec 26, 2011 9:19 pm |
Sorry my bad. I admit I glossed over that bit as he does actually say that.
And yes, agreed.
I have 500mm Monroes in and i am wondering if that was a bit too long as both of mine have now become useless, but after a number of offroad outings.
Would they be killed by just one decent bottom out or would it take a few??
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: No registered users and 167 guests
