| Biofuel? https://auszookers.com/forum/viewtopic.php?f=5&t=28966 |
| Author: | stilletto_rebel [ Mon Dec 26, 2011 1:02 am ] |
| Post subject: | Biofuel? |
I run an '88 Sierra (pictured left). Would running an ethanol blend be detrimental to the engine's health? |
| Author: | youda [ Mon Dec 26, 2011 2:08 am ] |
| Post subject: | Re: Biofuel? |
im not sure how engine will run but if its a high ethnol content fuel replace any very old rubber fuel hoses and replace your fuel filters after a 3-4 tanks of fuel (something i picked up from the boys running e85 in their fast cars). let me know how the car runs if you try it as i would be very interested. |
| Author: | ZookFan [ Mon Dec 26, 2011 6:00 am ] |
I have heard that the Bio fuel is not that good for carby cars... both my Dad's GQ RB30 and My mum's old 94 sierra ran rough as on the stuff... ran much better on regular 95 I might be very wrong tho! |
| Author: | christover1 [ Mon Dec 26, 2011 6:41 am ] |
I would not use it, without out proper modifucation to fuel system. http://www.fcai.com.au/publications/all ... nd-petrol- |
| Author: | Gwagensteve [ Mon Dec 26, 2011 7:21 am ] |
Don't do it. E10 might be ok (but your car is unlikely to run as well) but actual "biofuel" implying E85 or pure ethanol will cause corrosion to your fuel system and degradation of all the rubber fuel parts- not just the lines, but potentially the diaphragm in the fuel pump and seals etc in the carby. E85 compatible fuel systems are quite specialised. Steve. |
| Author: | ZookFan [ Mon Dec 26, 2011 7:28 am ] |
Gwagensteve wrote: Don't do it. E10 might be ok (but your car is unlikely to run as well) but actual "biofuel" implying E85 or pure ethanol will cause corrosion to your fuel system and degradation of all the rubber fuel parts- not just the lines, but potentially the diaphragm in the fuel pump and seals etc in the carby.
E85 compatible fuel systems are quite specialised. Steve. That's exactely what I was thinking but could not put into words |
| Author: | stilletto_rebel [ Mon Dec 26, 2011 8:47 am ] |
Ok, thanks chaps. I'll just convert to LPG instead. |
| Author: | shep [ Mon Dec 26, 2011 8:58 am ] |
stilletto_rebel wrote: Ok, thanks chaps. I'll just convert to LPG instead.
whats wrong with unleaded? |
| Author: | Bruce [ Mon Dec 26, 2011 8:59 am ] |
shep wrote: stilletto_rebel wrote: Ok, thanks chaps. I'll just convert to LPG instead. whats wrong with unleaded? Nothing |
| Author: | shep [ Mon Dec 26, 2011 9:00 am ] |
Bruce wrote: shep wrote: stilletto_rebel wrote: Ok, thanks chaps. I'll just convert to LPG instead. whats wrong with unleaded? Nothing my thoughts as well. spend 2k so ya can save $3 on a tank of fuel. |
| Author: | ZookFan [ Mon Dec 26, 2011 9:10 am ] |
I know crazy hey.. on a zook that is! |
| Author: | Bugsta [ Mon Dec 26, 2011 11:26 am ] |
I ran my old 1967 Holden on standard E10 for a few years and it ran better than the 92 rubbish. It pinged like crazy but was beautiful on E10. This is because the Ethanol actually increases the Octane level of the fuel. People will say that you need to modify your engine to same spec for GAS because its harder on the valve seats etc. My father made a very good point. If you're going to remove and rebuild the engine only for that reason, just use it till it needs a rebuild and do the mods then. That way you'll get that extra life out of it. Against my mechanics recommendations, I run my Diesel van on B20 (20% Biodiesel) and have had no issues other than a injector pump but I don't think that was fuel related. I notice no difference in power or ecenomy. However, just as a side note, I did get 20~25% more k's out of a tank immediately after replacing the collapsed exhaust system with a bigger system. And thats compared to new carrying less gear than I did 7 years later. |
| Author: | 303zuke [ Mon Dec 26, 2011 11:40 am ] |
shep wrote: stilletto_rebel wrote: Ok, thanks chaps. I'll just convert to LPG instead. whats wrong with unleaded? In NSW, Unleaded is to be phased out from 1 July 2012 and only E10 will be available. 95 and 98 fuels will continue to be Ethanol-free, but nearly 20cpl more expensive. http://www.biofuels.nsw.gov.au/biofuels_faq |
| Author: | Bugsta [ Mon Dec 26, 2011 12:50 pm ] |
303zuke wrote: shep wrote: stilletto_rebel wrote: Ok, thanks chaps. I'll just convert to LPG instead. whats wrong with unleaded? In NSW, Unleaded is to be phased out from 1 July 2012 and only E10 will be available. 95 and 98 fuels will continue to be Ethanol-free, but nearly 20cpl more expensive. http://www.biofuels.nsw.gov.au/biofuels_faq Whats funny about that is that Freedom Fuels here (my favourite fuel supplier) used to do only Bio fuels. After a couple of years they dropped their mid rating E10 and brougt back standard unleaded because the demand was still too great. I was dissappointed to see that. |
| Author: | abclarke [ Mon Dec 26, 2011 9:58 pm ] |
303zuke wrote: shep wrote: stilletto_rebel wrote: Ok, thanks chaps. I'll just convert to LPG instead. whats wrong with unleaded? In NSW, Unleaded is to be phased out from 1 July 2012 and only E10 will be available. 95 and 98 fuels will continue to be Ethanol-free, but nearly 20cpl more expensive. http://www.biofuels.nsw.gov.au/biofuels_faq Fuck that shit... |
| Author: | Scrawny [ Mon Dec 26, 2011 10:04 pm ] |
Bugsta wrote: Against my mechanics recommendations, I run my Diesel van on B20 (20% Biodiesel) and have had no issues other than a injector pump but I don't think that was fuel related. I notice no difference in power or ecenomy. However, just as a side note, I did get 20~25% more k's out of a tank immediately after replacing the collapsed exhaust system with a bigger system. And thats compared to new carrying less gear than I did 7 years later.
Bio-diesel goes really well in mechanical injection diesels. Common rail diesels don't like it too much, and they're expensive to fix when they stop |
| Author: | Bugsta [ Tue Dec 27, 2011 9:14 am ] |
Mine is not common rail a far as I know. MB100 |
| Author: | steak_knife [ Tue Dec 27, 2011 12:38 pm ] |
Scrawn wrote: Bugsta wrote: Against my mechanics recommendations, I run my Diesel van on B20 (20% Biodiesel) and have had no issues other than a injector pump but I don't think that was fuel related. I notice no difference in power or ecenomy. However, just as a side note, I did get 20~25% more k's out of a tank immediately after replacing the collapsed exhaust system with a bigger system. And thats compared to new carrying less gear than I did 7 years later. Bio-diesel goes really well in mechanical injection diesels. Common rail diesels don't like it too much, and they're expensive to fix when they stop That get used 14 out of 24 hr's a day... |
| Author: | wipikafish [ Tue Dec 27, 2011 10:14 pm ] |
303zuke wrote: shep wrote: stilletto_rebel wrote: Ok, thanks chaps. I'll just convert to LPG instead. whats wrong with unleaded? In NSW, Unleaded is to be phased out from 1 July 2012 and only E10 will be available. 95 and 98 fuels will continue to be Ethanol-free, but nearly 20cpl more expensive. http://www.biofuels.nsw.gov.au/biofuels_faq This is a dumb and extremly offensive thing to do... Why take away a consumers right to choice??? Yes, 'Biofuels' are nice for the environment and they keep Bob Brown and his cronies employed... But look at the sky rocketing cost of food - especially in the third world, where they cant afford food in the first place... Im sure the poor guy who thought of Biofuels didnt think it would lead to this... Now youve got a global food crisis because food crops are being replaced with fuel crops because it pays more. Consequently, youve got millions of people dying each day because they cant afford food... It pisses me right off petrol stations fer phasing out unleaded before July - And I tell them too... |
| Author: | stilletto_rebel [ Tue Dec 27, 2011 10:56 pm ] |
shep wrote: Bruce wrote: shep wrote: stilletto_rebel wrote: Ok, thanks chaps. I'll just convert to LPG instead. whats wrong with unleaded? Nothing my thoughts as well. spend 2k so ya can save $3 on a tank of fuel. But obviously over time the 2K investment will pay off. I converted my first Mazda MX5 to LPG. It cost me 1,500 GBP and took 8 months to break even on the outlay. I was 3k in the black when I sold it and emigrated here. I calculate the $1,250 it'll cost me to convert (as $1,250 is rebated) will be paid back in four months, judging by my current mileage and fuel costs. IMO you'd be not to consider conversion.;
| Author: | 303zuke [ Wed Dec 28, 2011 4:22 am ] |
wipikafish wrote: 303zuke wrote: In NSW, Unleaded is to be phased out from 1 July 2012 and only E10 will be available. 95 and 98 fuels will continue to be Ethanol-free, but nearly 20cpl more expensive. http://www.biofuels.nsw.gov.au/biofuels_faq This is a dumb and extremly offensive thing to do... Why take away a consumers right to choice??? Yes, 'Biofuels' are nice for the environment and they keep Bob Brown and his cronies employed... But look at the sky rocketing cost of food - especially in the third world, where they cant afford food in the first place... Im sure the poor guy who thought of Biofuels didnt think it would lead to this... Now youve got a global food crisis because food crops are being replaced with fuel crops because it pays more. Consequently, youve got millions of people dying each day because they cant afford food... It pisses me right off petrol stations fer phasing out unleaded before July - And I tell them too... So when you replied, you knew that: 1. Barry O'Farrell is a Liberal Party Premier of NSW, and does not go much for the Greens. 2. Most Ethanol production in Australia comes from Wheat Stubble, Sugar Cane Trash, or as a by-product of Natural Gas production. Not many of these sources feed people in the Third World. 3. Service Stations (especially the person behind the counter) don't have any say in the matter. It has been dictated by the State Govt to the Fuel Distributors who then supply the Service Stations. |
| Author: | tonyevans [ Wed Dec 28, 2011 4:37 am ] |
303zuke wrote: wipikafish wrote: 303zuke wrote: In NSW, Unleaded is to be phased out from 1 July 2012 and only E10 will be available. 95 and 98 fuels will continue to be Ethanol-free, but nearly 20cpl more expensive. http://www.biofuels.nsw.gov.au/biofuels_faq This is a dumb and extremly offensive thing to do... Why take away a consumers right to choice??? Yes, 'Biofuels' are nice for the environment and they keep Bob Brown and his cronies employed... But look at the sky rocketing cost of food - especially in the third world, where they cant afford food in the first place... Im sure the poor guy who thought of Biofuels didnt think it would lead to this... Now youve got a global food crisis because food crops are being replaced with fuel crops because it pays more. Consequently, youve got millions of people dying each day because they cant afford food... It pisses me right off petrol stations fer phasing out unleaded before July - And I tell them too... So when you replied, you knew that: 1. Barry O'Farrell is a Liberal Party Premier of NSW, and does not go much for the Greens. Can't help that 2. Most Ethanol production in Australia comes from Wheat Stubble, Sugar Cane Trash, or as a by-product of Natural Gas production. Not many of these sources feed people in the Third World. True but is causing shortages in other places like Europe 3. Service Stations (especially the person behind the counter) don't have any say in the matter. It has been dictated by the State Govt to the Fuel Distributors who then supply the Service Stations. One service station has dumped ULP in Lightning Ridge but the other two still have it |
