It is currently Sun Nov 08, 2026 8:52 am
Vehicle: 98 Maruti
Post Posted: Mon Dec 26, 2011 2:16 am
i have just recently put a replacement 1.3 into my sierra, everything went well and it was running and idling. while it was idling i stupidly opened the butterfly valve at the top of the carby and it flooded with fuel and stalled out. now i can not get it started again.
i have
pulled plugs, cleaned and dried
checked its getting fuel
checked spark
checked carby (just rebuilt) everything is in its place
turned cylinder over to clear bores
tried aero start and nothing
is there something i am missing?, the leads are in correct sequence to
Vehicle: 98 Maruti
Post Posted: Mon Dec 26, 2011 4:09 pm
it seams that cylinder 1 and 2 are the only ones to be fouled with fuel
Post Posted: Mon Dec 26, 2011 6:53 pm
Is the timing close to right?
Std fuel pump?
cam & crank bolt's TIGHT?
Spark plug gap right??
Vehicle: 98 Maruti
Post Posted: Tue Dec 27, 2011 1:59 am
timing is just past 10
std fuel pump
new spark plugs
from what i know cam and crank bolts are tight
Vehicle: 98 Maruti
Post Posted: Wed Dec 28, 2011 12:17 am
managed to start it today,
after cleaning plugs, clearing bores, one squirt of aero start she started BUT idles rough, everything seams normal then fuel will dump out of the two openings on the carby and it will stall out.
i have tried holding the acel a little to keep the revs up but will still stall out
Vehicle: 98 Maruti
Post Posted: Wed Dec 28, 2011 3:38 am
the engine will start and after roughly 20seconds fuel will start flowing out of the holes in the above picture and stall it out.
i think i may have something connected up wrong, does anyone have any ideas? i have looked over the carbys vac and coolant lines and everything looks like it is in its place.
Post Posted: Wed Dec 28, 2011 10:37 am
Float is set incorrectly or your tank return is blocked.....
Vehicle: 98 Maruti
Post Posted: Wed Dec 28, 2011 9:00 pm
i talked to a carby specialist who suggested replacing my fuel filter and giving the top of the carby a tap with a dead blow hammer. surprisingly it worked and i was able to start and run the engine yesterday. he though since my fuel filter was old a bit of crap could have made its way into the carby.
thank you for the help mate
Vehicle: I drive your mum
Post Posted: Thu Dec 29, 2011 12:34 am
Gotta love the hammer fix. Sounds like some crap had made its way up into the needle and seat valve and was holding it open.
Layto....
Vehicle: 98 Maruti
Post Posted: Fri Dec 30, 2011 12:56 pm
well bad news for me, halfway to a campsite today i pulled over for a second and when i took off again it stalled out, i checked out teh carby and the dumping fuel after 20seconds was back :(
tomorrows job is to take the carby apart again and clean anything out from the needle and seat
big thanks to steky for help trouble shooting and LAY80N to
Post Posted: Fri Dec 30, 2011 2:34 pm
use a bigger hamma
Users browsing this forum: No registered users and 158 guests
