It is currently Sun Nov 08, 2026 8:52 am
Post Posted: Fri Dec 30, 2011 1:41 am
It sounds simple but the globes are good and I can't find any fuses has anyone had this problem if not got any ideas on what it could be thanks any help would be much appreciated
Vehicle: 1985 Holden Drover
Post Posted: Fri Dec 30, 2011 1:45 am
Checked the earths? Every problem ive had with my lights thats been the trick! :lol:
1989 WT Sierra.
Fuses are under the dash on the driver's side, mounted on the firewall.
Check the earths/grounds too.
Post Posted: Fri Dec 30, 2011 1:56 am
There all good I should if said it's just the left hand side front two there's no power getting there and I've stripped it back near the washer bottle
Post Posted: Fri Dec 30, 2011 1:59 am
If the earth/ground for those two lights is OK then start tracing the power wire back to the fuse and see where it's cut/broken.
Post Posted: Fri Dec 30, 2011 2:31 am
It's cut or broken in-between the fire wall and where the plug is under the glove box I'm going to route another wire to the plug in the engine bay
Post Posted: Fri Dec 30, 2011 2:36 am
I have never seen a broken wire in a Sierra loom, not saying it isn't possible but certainly very rare.
If you have a left rear but no front, the problem could be the joiner plug behind glovebox or even the indicator switch itself as there are two sets of contacts for both front and rear.
Post Posted: Fri Dec 30, 2011 3:48 am
The earth is generating power and I have no idea how I guess I'm residing the indicators now hahahah what a great way to spend the afternoon
Post Posted: Fri Dec 30, 2011 3:51 am
if you are seeing power on the earth then the earth isnt attached to anything
Post Posted: Fri Dec 30, 2011 4:17 am
All good all fixed mounted earth to the radiator mount the earth it was using was shonky so all fixed thanks for the help I love this forum very helpful
Users browsing this forum: No registered users and 159 guests
