https://auszookers.com/forum/
g13bb with g16b bottom end.
https://auszookers.com/forum/viewtopic.php?f=5&t=29163
Page 1 of 2
Author:  jonno_racing [ Sun Jan 01, 2012 3:27 pm ]
Post subject:  g13bb with g16b bottom end.
hey all, happy newyears! just a question, whats the implications with 1600 bottom end under jimny head?? is it as straight forward as bolt up?
Author:  Gwagensteve [ Sun Jan 01, 2012 7:38 pm ]
Post subject:  Re: g13bb with g16b bottom end.
Yes - the heads are all the same, so you'll need an appropriate timing belt ( be aware there's a couple of options) and that's it.
Author:  MrRocky [ Sun Jan 01, 2012 8:40 pm ]
the 1600 bottom end isnt really considered to be a good platform for turbocharging when compared with the 1300 if thats what your thinking
Author:  jonno_racing [ Sun Jan 01, 2012 9:51 pm ]
Nah mate not at all, I am after trouble free motoring, so no boost etc
Author:  suzooky87 [ Mon Jan 02, 2012 1:40 am ]
then do a complete 1.6 conversion...............
Author:  steak_knife [ Mon Jan 02, 2012 1:43 am ]
Why???
Nothing wrong with the Jim Inj...... :helloo:
Author:  alien [ Mon Jan 02, 2012 1:53 am ]
my zuk runs this setup and it goes great and looks factory.
you'll also need the hose that lets you use the standard sierra airbox (its not cheap either!)
Author:  steak_knife [ Mon Jan 02, 2012 1:58 am ]
Um....... Jimny.......
Author:  alien [ Mon Jan 02, 2012 2:25 am ]
hahaha oh yeah... i just assume when 1.6 is mentioned its for a sierra =)
...i miss my sierra =(
Author:  jonno_racing [ Mon Jan 02, 2012 11:33 am ]
u sold your Sierra?
any issues with lean/rich issues?
Author:  alien [ Mon Jan 02, 2012 1:09 pm ]
i didnt sell it - i broke it and cos of this shitty time of year im waiting for parts =(
i get no lean/rich issues... just tons of torquey powery goodness... enough to destroy my driveshafts =D
Author:  steak_knife [ Mon Jan 02, 2012 11:11 pm ]
jonno_racing wrote:
u sold your Sierra?
None I've seen, I'm told there is 3 different map's in the ecu that can be changed by changing the res to earth of the ecu, but haven't confirmed this or tested it.
The jim ecu will run a 1.6 no worry's....
Author:  Gwagensteve [ Tue Jan 03, 2012 12:32 am ]
I didn't think they were "maps" as much as idle mixture to pass emissions.
Author:  steak_knife [ Tue Jan 03, 2012 12:35 am ]
I'm just going on what I was told......
If it's just for idle it could explain a lot of missing & almost stalling at idle... :?
Author:  jonno_racing [ Wed Jan 04, 2012 3:50 am ]
it sounds very simple, where would I get more info on maps etc?
Author:  steak_knife [ Wed Jan 04, 2012 3:56 am ]
http://auszookers.com/index.php?name=Yo ... ofile=3386
He may be able to help, t'was he that mentioned it...
Author:  mud_muncher [ Mon Jan 09, 2012 5:09 am ]
What sort of cost are involved in going a bottom end G16 Conversion using the G13bb injectors and head?
Author:  neofitou [ Mon Jan 09, 2012 7:15 am ]
Didn't you just put a 1.6 in your car.....?
Author:  zammit [ Mon Jan 09, 2012 7:30 am ]
hey guys sorry to crash the party.. but is it as simple as getting a 1.6 block and swaping everything over? i have a jimny also and im interested in doing this. are the timing belts and everythig the same?
Author:  atari4x4 [ Mon Jan 09, 2012 7:51 am ]
:helloo:
Author:  zammit [ Mon Jan 09, 2012 10:12 am ]
Woops. Hahaha so I take it if the heads are the same the timing belt will be that of a g16b
Author:  Rhinoman [ Mon Jan 09, 2012 11:07 am ]
Standard there are usually several different setups with two different pairs of fuelling and timing maps which can be changed by inserting or removing configuration resistors. The G13BB is reflashable so it is also possible to change the mapping to the 1.6 mapping.
The 1.3 ECU does seem to run the 1.6 OK but the maps are different shapes so it won't be optimum.
Author:  Rhinoman [ Mon Jan 09, 2012 11:08 am ]
I think that you'll need the G16 injectors.
Author:  alien [ Mon Jan 09, 2012 12:14 pm ]
yup.
Author:  zammit [ Tue Jan 10, 2012 12:22 am ]
Hey alien is a 1.6 or 1.3 flywheel and clutch used? I'm guessing 1.3 but just to be sure
Author:  zammit [ Tue Jan 10, 2012 12:23 am ]
Author:  Fatzook [ Tue Jan 10, 2012 12:36 am ]
1.3. You'd need to run the 1.6 gearboc to fit the 1.6 flywheel and clutch, as they are bigger and do not fit into the 1.3 bell housing.
Author:  alien [ Tue Jan 10, 2012 1:10 am ]
what he said.
i run a jimny clutch in mine... has lots of clamping pressure compared to sierra =)
Author:  zammit [ Tue Jan 10, 2012 2:14 am ]
Yeah that's what I thought fatzook! I'm going to look at a 1.6 block out of a vitara this weekend and if it's all good I'll start the conversion in Feb! The blocks are basically the same arnt they? So power steer alternator ect will just bolt up?
Author:  Fatzook [ Tue Jan 10, 2012 2:17 am ]
Nope. the 1.6 block is slightly taller. You will need to mod the brackets for the P/S. Not sure about ALT. Be carefull to check your belts fit the ACC's as well.
Don't be put off by this. Modding brackets is the easy part :wink:
Page 1 of 2 All times are UTC + 9:30 hours
