It is currently Sun Nov 08, 2026 11:10 pm
Post Posted: Thu Jan 05, 2012 11:00 am
Repco don't list the correct spigot bearing for the 1.0L. It's a 10 x 15 x 15 needle roller and it's OD makes it too hard for the local bearing shop. Anyone got any ideas other than Suzistore?
www.bulldogtrimming.com
Post Posted: Thu Jan 05, 2012 11:10 am
thats a prick of a size.
i would say a sinted bronze bush would be the go
Vehicle: LJ50V, SJ70
Post Posted: Thu Jan 05, 2012 12:31 pm
Have you actually got the motor out yet?
Most (Many? Some??) F10A cranks are drilled with a stepped spigot bore. They have a deep hole to accept a long gearbox shaft and the needle roller bearing, and also a shallower, wider hole that accepts a 6300 sealed roller bearing that was also used on the 1.3. The 6300 bearing also has a 10mm ID and sits further along the input shaft, meaning that if you have worn the part of the shaft that the needle roller runs on, by changing over to a 6300 ball bearing, you get a "New" bearing shaft surface!
Post Posted: Sat Jan 07, 2012 5:37 am
Alas, mine is not one of these. I was wondering why the 4sp had such a long shaft and this explains it. I was equally worried that the shorter shaft of the 5sp may be a problem. Do you think the short shaft with the needle roller bearing will be a mismatch?
Post Posted: Sat Jan 07, 2012 5:38 am
Can you buy sintered bronze in solid pieces do you know? I have a lathe(not that I'm that good at using it) and could make one if that's the best option
Users browsing this forum: No registered users and 80 guests
