| Flywheel Bolts https://auszookers.com/forum/viewtopic.php?f=5&t=29302 |
| Author: | rwt65 [ Thu Jan 05, 2012 9:53 pm ] |
| Post subject: | Flywheel Bolts |
I am after the specs for flywheel bolts, what thread size and diameter? Do they vary from model to model? Want to get new replacements, what do I need to get? Cheers Richard T |
| Author: | squibby [ Thu Jan 05, 2012 10:13 pm ] |
| Post subject: | Re: Flywheel Bolts |
Stretch bolts probably. We should buy new ones when we replace them, probably best to get them from the dealer since they are a specialised item imo. That said I have been naughty and re-used them myself with no explosions as yet, although I'd definately buy new ones the second time they are undone. You'll need eight of them on a M-series engine. |
| Author: | rwt65 [ Thu Jan 05, 2012 10:40 pm ] |
| Author: | want33s [ Thu Jan 05, 2012 10:49 pm ] |
squibby wrote: Stretch bolts probably. .................................................
No they aren't. They are fine to reuse if they aren't damaged. You can pick a single use bolt by the torque settings in the FSM. Normal reusable bolts just have a set torque rating to tighten to.. EG 40Nm Single use bolts will be EG 40Nm plus a quarter turn. |
| Author: | squibby [ Thu Jan 05, 2012 11:00 pm ] |
want33s wrote: No they aren't.
oh good |
| Author: | Rhinoman [ Fri Jan 06, 2012 9:12 pm ] |
Use threadlock when you replace them, they have a habit of falling out if you don't. |
| Author: | whincup [ Fri Jan 06, 2012 11:57 pm ] |
Rhinoman wrote: Use threadlock when you replace them, they have a habit of falling out if you don't.
x2 http://www.auszookers.com/index.php?nam ... 07&start=0 |
