It is currently Sun Nov 08, 2026 5:35 pm
Post Posted: Sun Jan 08, 2012 9:12 am
Tried to start my car but seemed like the battery was a bit flat... DIDNT START.. now the malfunction indicator light' comes on.. which is a problem with the EMISSION CONTROL SYSTEM... what exactly cause this??
I belive it must be the sensors for the fuel injection or a charging problem??
I can JUMPSTART the car with jumper leads and can drive it quite fine, 'the MALFUNCTION INDICATOR LIGHT stays on.. and once stopped it wont start again
HOW DO I FIX IT??
WHAT CAUSES IT??
any help would be fantastic!!
Post Posted: Sun Jan 08, 2012 9:19 am
disconnect battery and charge it fully out of the car and then try again in the morning.
connect the battery with ignition off. let it sit connected with ignition off for 10 mins and then try to start it. Computer will reset and it should be all good. if not read your Owners Manual
Post Posted: Sun Jan 08, 2012 9:24 am
cheers will try, I believe if u disconnect the battery u loose all ur memory??.. manual says.. Bring you vehicle to RIPOFFS...'SUZUKI DEALER' to have the prob corrected..
Post Posted: Sun Jan 08, 2012 10:06 am
If it doesn't have esp or anything silly you should be fine removing battery.
Post Posted: Sun Jan 08, 2012 10:52 am
what if it does have esp. what would happen if ya pulled the battery out?
Post Posted: Sun Jan 08, 2012 11:01 am
would loose all settings on all electronic settings.. eg.. windows work on a timed setting via the computer.. I removed the battery and swapped it with another battery I had.. battery was completely f@#$ed in the GV.. soo works quite well now :D
Post Posted: Sun Jan 08, 2012 8:47 pm
ESP has to be reset, pain in the butt, but must be done......
Users browsing this forum: No registered users and 56 guests
